Results 1 to 10 of 11
- Oct 2006
- 60
August 28th, 2007 08:10 PM #1I notice some bubbles in my starex receiver dryer when the engine and aircon has just been recently shut off, but after a while it dissapears but no bubbles during air con operation, Is this any indication of damage parts?
Thanks for the help.
August 28th, 2007 09:57 PM #2
ganyan din kotse ko, sabi nung aircon specialist sakin normal lang may bubbles kasi di totally puno ng freon yung drier, sadya yun para may onti space para daw di hirap compressor
August 28th, 2007 10:22 PM #3
bubbles in the refirgerant sight glass is normal only...
1. when the ac compressor had just been turned on (ac clutch is engaged) as the refrigerant has not yet been fully liquified in the high side (or condenser side) of the refrigerant system. when the pressure in the high side has reached its design pressure then there should be no more bubbles seen in the sight glass.
2. when the ac compressor had just been turned off (ac clutch is off) because the remaining liquid refrigerant vaporizes as the pressure between the high side (condenser) and low side (evaporator) equalizes.
when the ac compressor* has been running for a while there should be no more bubbles in the sight glass. bubbles in the sight glass is a sign of undercharge.
*compressor ha, hindi yung ac lang kasi pwede naka-on ang ac pero off ang clutch ng compressor.Last edited by yebo; August 28th, 2007 at 10:25 PM.
August 29th, 2007 09:55 AM #4
Pag tuloy tuloy pa din yung bubbles pag matagal na naka engage and aircon compressor, meaning to say kulang na din sa freon.
- Oct 2006
- 60
September 6th, 2007 12:34 PM #5Thanks for your reply, but my queries the bubbles appear just after the air con and engine has just been turned off and dissapears after a while.
Thanks again
- Oct 2004
- 278
September 7th, 2007 01:15 AM #6
September 7th, 2007 06:23 AM #7
there should be a very little-miniscule amount of bubbles you can see even if the ac is on.. wheen you see its totally clear, its might be an indication of too much freon in the system.
but when the bubles dont stop, means lesser freon on the system, might be a leak somewher--hanapin mo yung malangis..
when the glass is so dirty, time to clean and replace the reciever/drier and the expansion valves.. and have your condensers, evaporators, solenoid valves, lines and commpressor undergo general flushing...
September 7th, 2007 11:26 AM #8
"but when the bubles dont stop, means lesser freon on the system"
true only for R12 system not with the R134A system, yan ang reason why most R134A receiver/drier ay walang sight glass
- Oct 2004
- 278
September 7th, 2007 08:39 PM #9My R134A drier has a sight glass....
minsan may bubbles, minsan wala...
...pero di talaga dapat basis yung bubbles lang 'coz pwedeng overcharged na yung refrigerant, pero may bubbles pa rin... The pressure has to be checked on both high and low pressure sides talaga. Pwede kasing loose compression na yung compressor, or pwedeng yung expansion valve ay kailangan nang palitan...
- Nov 2004
- 141
September 11th, 2007 08:59 AM #10normal lang ang bubbles. pressure naman ang tinitingnan sa linya ng A/C, hindi ang bubbles
Looks like its is due for release next year: https://www.youtube.com/watch?v=1mLrd78Deng Also...
2026 Mazda CX-5
