Results 21 to 25 of 25
- Mar 2005
- 23
June 7th, 2005 02:47 PM #21Hi
that happened also to my Kia...may leak yung water pump ko...yung reservoir tank ko nauubusan rin and also mga 1/3 of the radiator tank..I replaced the fuel pump tapos ok na siya....
June 7th, 2005 02:50 PM #22
dpat isang trabaho nalang lahat dati, pinalitan na lahat para di na uli baklasin..sayang
June 7th, 2005 03:03 PM #23
Re overheating: Tumataas ba temp pag stop and go traffic? Meaning pag umaandar na eh bumababa ang temp at tumataas lang pag naka stop? If this is the case, might be the thermostat. Pag nauubos parati water reservoir mo, may pressure leak ka somewhere kaya di bumabalik water from radiator to the reservoir: 1. cylinder gasket 2.radiator cap 3. sa water reservoir mismo. 4. hoses 5. others ( di ko na alam).
Hope this helps
June 8th, 2005 05:49 PM #25
no idea... meron na sigurong outside-casa sources kahit yung ES kasi 5-year old model na yun.
i suppose, it's ok for empty nest syndrome owners who do not drive to farther-flung areas. ......
VinFast VF 3
