Ano kaya problem ko sa car ko na honda LXI. Nagstuck up sya sa 1500rpm pagtigil ko tapos babagsak sa normal nang 900rpm mga 20 seconds din ang tagal nun.
Pag hindi bukas ang aircon minsan nararamdaman ko pero pagbukas lagi na lang ganun. Ang lakas tuloy nang gasoline ko.
Bagong palit ang timing belt, idle bearing; air filter saka bagong linis yung spark plug.
yes, it does sound like a leak in that vacuum for idler up, kung carb and not EFI yan LXI mo another suspect could be a dirtly gas cable and/or madumi na mechanical linkages sa carb.
For the latter, a good cleaning with a carb spray cleaner or WD40 might help.
yes, have the idle up checked and also make sure your engine has the correct timing. i'm sure the problem will just require a simple adjustment to solve
Before kasi hindi naman ganun kalakas ang gasoline and hindi naman nagstuck up yung gasoline rev ko. After na nagpalit nang timing belt and idle bearing parang ang lakas humatak saka ang lakas din gasoline. No. 3 gear palang ang tulin na katakot nga sa gitgitan.
okay ka rin ah ayaw mo ng mabilis....anyway malamang a good "re-tune-up" would be needed (preferably casa ng honda or somebody how really know how to tweak honda's)...baka nagalaw ang mga settings when those were changed...
