Results 1 to 10 of 15
May 31st, 2008 05:04 PM #1
Hello guys, meron kasing tumutulo na langis(?) galing sa clutch pedal ko. Toyota Liteace 92 ang sasakyan ko. pinasilip ko sa mekaniko sa isang gas station, ang sabi ng mekaniko wag ko daw masyado tapakan ang clutch(?) ngek
, wag ko tapakan ang clutch? paano aandar ang sasakyan nyan? hehehe.
ano po kaya nag problema ng saksakyan?
- Jan 2007
- 409
May 31st, 2008 06:41 PM #2
June 1st, 2008 03:33 AM #3
oil seal o yun mga guma nya sa loob ng master, di naman ganun kamahal yan pa gawa mo na, baka itirik ka pa nyan sa alanganin lugar o expressway ma tow ka pa mas mapapamahal ka lalo..
June 1st, 2008 05:26 AM #4
They are booth right. The primary seal is leaking in the master cylinder(not the slave) and that fluid is oooooooooozing out of the rear then into your clutch pedal all the way to the carpet. Thats nasty, oil in the carpet!
The good news is repair kit wont cost that much and easy to fix.
The bad news is you may need a new master (not kung fu master) a master cylinder depending how bad it is.
Now here come's the ugliest... ethier one of theme gagastos ka.
June 1st, 2008 07:31 AM #5
salamat po
sa mga sagot nyo. ipatitingin ko na agad sa matinong mekaniko. sana hindi malaki ang sira....
June 2nd, 2008 09:19 AM #6
based on experienced, repair kit wont last for me pero kung bibili ka na ng buo with the cylinder mas tatagal pa more than 2yrs. anyway new master cost only 600 to 700 not bad for long time use. Mostly kaya nasisira ang rubber dahil sa magaspang or damage na ang wall ng cylinder.
- Jan 2008
- 380
June 2nd, 2008 09:23 AM #7Pagawa mo agad yan kung ayaw mong tumirik bigla. Sandali lang gawin yan, kung nasa 'tipid mode' ka ngayon, pakiusap mo sa mekaniko, repair kit lang muna, dala ka ng brake fluid (mga half liter) at 800 to 1200 grit sand paper.
Kung minsan pag bagito pa mekaniko ang tagal ng bomba bago mawala yung basyo, at sasabihin na kelangan bili na talaga ng bagong unit, pero tiyaga at diskarte lang yan.
Yung iba salabas nila pina-prime (bleeding) yung master cylinder, at para ngang mas mabilis ito.
Tsikot Member Rank 5
- Nov 2003
- 3,848
June 3rd, 2008 09:24 AM #8replace the whole clutch master assembly imo. mas tatagal. check also the slave, it might need replacing soon so you might as well do it together para tipid sa brake fluid.
July 1st, 2008 08:58 PM #9
- Jan 2008
- 380
July 2nd, 2008 10:43 AM #10Opo, mga 600 to 700 lang yung low cost replacement. Ang Repair kit mga 150 to 200 petot.
Yung medyo 'kalidad daw', mga 900 petot up.
