Results 1 to 10 of 13
- Nov 2007
- 14
November 19th, 2007 06:50 PM #1kung may halong tubig ang fuel, pwede kaya dito yung additives na nilalagay para matanggal ang tubig at malinis ang carb at kung anu ano pa...
- Jun 2004
- 103
November 20th, 2007 02:05 AM #2I also experienced that before on a 98 L300 Exceed gas. Bigla na lang mawawalaan ng power while driving. When it happened, we had to downshift and travel slowly. Turned out na barado ang fuel filter so kinakapos sa gas.
This happened about every 3-months and we had to change fuel filters regularly. We later found out that the real cause was madumi ang fuel tank - which quickly clogged the fuel filter. When we cleaned the fuel tank, the problem went away.
Hope this helps.
November 20th, 2007 03:45 AM #3
Saan ba kayo nagpapalinis ng fuel tank? Anu actually ang ginagawa nila? Normally how much is the cost?
November 20th, 2007 05:27 AM #4
sa gasoline station, para maibaba ang fuel tank at malinisan ng husto... provided may drain siya...
nagawa ko na iyan sa car ko pero sa chevy dealership ko pinagawa dahil walang drain plug kasi iyun Optra... (grabe mahal singil nila)
pero kung may time at sanay ka mag butingting pwede mo DIY...
- Nov 2007
- 14
Tsikot Member Rank 5
- Nov 2003
- 3,848
someones are (at last!) loudly asking, "why did they turn off the countdown timers?"
SC (temporarily) stops NCAP
