Results 1 to 10 of 15
- Aug 2003
- 91
- Jan 1970
- 396
May 24th, 2004 04:24 PM #2depending on manufacturers, it ranges from 70T to 100Tkm. i just changed mine at 75Tkm, and the belt still looks good. timing belt replacement is a very cheap thing to do, but if it breaks on you, it will cost you a whole lot!
- Aug 2003
- 91
May 24th, 2004 07:42 PM #4
follow the owner's manual. 80K sa civic ko. ok pa yung itsura. i think sa mazda 100K pa. mazda owners, correct me if i'm wrong.
maraming sisirain kapag napatidan ng timing belt kaya di dapat i-neglect yan.
May 25th, 2004 02:35 AM #5
dati meron kami gen 1 crv nakalagay sa manual 80k km ang palit ng timing belt.
June 4th, 2004 12:12 AM #7
better safe than sorry...
pag naputulan ka ng timing belt, tatama valves mo sa piston causing it to bend. kailangan mo na magpa o/h.
Tsikot Member Rank 5
- Nov 2003
- 3,848
June 4th, 2004 01:59 PM #8usually manufacturers recommend between 70-80t kms. kung chain gamit over 100t kms kaya pa.
June 6th, 2004 07:21 PM #9
diba yung chain type di na pinapalitan, usually pag sobrang tagal na siguro?
- Nov 2003
- 3,848
June 8th, 2004 11:17 AM #10pinapalitan din yun kasi sometimes the tensioner goes which means better na isabay nalang sila
usually nga matagal bago mangyari ito.
I have a digital gauge that measures, among other things, engine coolant temp. 90% of the time,...
