Results 1 to 10 of 15
- Aug 2003
- 91
- Jan 1970
- 396
May 24th, 2004 04:24 PM #2depending on manufacturers, it ranges from 70T to 100Tkm. i just changed mine at 75Tkm, and the belt still looks good. timing belt replacement is a very cheap thing to do, but if it breaks on you, it will cost you a whole lot!
- Aug 2003
- 91
May 24th, 2004 07:42 PM #4
follow the owner's manual. 80K sa civic ko. ok pa yung itsura. i think sa mazda 100K pa. mazda owners, correct me if i'm wrong.
maraming sisirain kapag napatidan ng timing belt kaya di dapat i-neglect yan.
May 25th, 2004 02:35 AM #5
dati meron kami gen 1 crv nakalagay sa manual 80k km ang palit ng timing belt.
June 4th, 2004 12:12 AM #7
better safe than sorry...
pag naputulan ka ng timing belt, tatama valves mo sa piston causing it to bend. kailangan mo na magpa o/h.
Tsikot Member Rank 5
- Nov 2003
- 3,848
June 4th, 2004 01:59 PM #8usually manufacturers recommend between 70-80t kms. kung chain gamit over 100t kms kaya pa.
June 6th, 2004 07:21 PM #9
diba yung chain type di na pinapalitan, usually pag sobrang tagal na siguro?
- Nov 2003
- 3,848
June 8th, 2004 11:17 AM #10pinapalitan din yun kasi sometimes the tensioner goes which means better na isabay nalang sila
usually nga matagal bago mangyari ito.
someones are (at last!) loudly asking, "why did they turn off the countdown timers?"
SC (temporarily) stops NCAP
