Page 1 of 2 12 LastLast
Results 1 to 10 of 11
    I noticed my car slightly veers to the left whenever i stepped on the brakes. What might be the cause? Di naman nagpu-pulsate.
    May 2004
    worn discs??
    - baka di parehas ng hangin ang mga gulong or
    - di properly aligned yung mga gulong mo sa harap.
    Dec 2003
    have your front tires checked.. probably wheel alignment and balancing..
    i agree with them, check mo po front wheels mo po.
    Aug 2004
    pa check mo narin brakes, sir.
    please check wheel alignment and balance, tire pressure, and brakes
    My analysis is that if it's because of alginment and wheel balancing, then why does it happen only during braking? I have a hunch that my right front brakes are not working.
    Dec 2003
    stuck brake piston..
    Jun 2005
    na-experience ko rin yan with my ES na civic. Slight lang naman ang kabig when braking. It went away when I replaced by tie rod, ball joint, stabilizer link and front suspensions. Problem is I dont know which one was causing it. Hope this helps. =)
kabig kapag nag-preno
