Results 1 to 14 of 14
    My wiper speed isn't that "perky" nor fast anymore. If I rate it siguro 0-10 with 0 being no movement and 10 being performance like brand new, mga 7 nalang siguro. New pa naman blades ko and bagong windshield detail from Bigberts. It looks like weak yung wiper motor. Ano kailangan kaya nito? Relay? Cleaning? Or replace motor brushes? Any shop that specializes in wiper motor troubleshooting? Thanks guys!
  2. FrankDrebin Guest
    Got a same problem with our L200. Bagong windshield detailed din Big Berts wala pa rin pero gumanda ang pag-wipe pero mabagal pa rin. New NWB wipers and a cheaper P160 wipers wala pa rin. Tinaas ko yung wiper ok naman ang pag-andar. Sabi nila sa bushing daw ng wiper. Hindi ko nga lang alam kung saan ipapagawa.
    bushings din ng motor ang problema ko, dinala ko sa servitek west ave., di ata nila kaya tirahin dun, wla paraw silang experience magpalit ng bushings, matagal daw kasi yun!
    sabi naman ni master ungas, kaya daw yun ng mga banawe boys, - ang hirap lang takot ako dun....
    any shops na recommended ng mga naka experience na ng ganito?
    hmmm hindi kaya yung wiper linkages and not the motor?
    Baka kulang lang kaya supply ng electricity to the motor. Relay kaya?
    pedeng relay and bushing problem. kailangan niyong kalasin para makita ang "play" sa bushing and kung relay, irekta lang sa battery ang nasa isip ko to check if may change of speed sa direktang contact.
    wala yatang nagagawa nyan specifically - i would DIY it if I were you.
    Wild, where exactly are these bushings located? Are these the bushings sa linkages or bushings inside the wiper motor itself?
    meron bushing sa motor (just like the electric fan motors) usually made in copper - may play na ang motor spindle. meron din bushing sa arm, usually plastic and metal...like a ball-and-socket configuration (parang shoulder ng tao). Pag iyun plastic ang ang nasira, palit ang buong arm assembly. Depende sa configuration .... mazda na pick-up kasi ang ride ku nuon na nasira....plastic ang problem...awa ng diyos meron nabibili na replacement assembly ng arm.
  9. FrankDrebin Guest
    Motorix daw gumagawa sila.
    Frank: Where is motorix located? Thanks!
    Motorix is in banawe near e rodriguez. although they specialize in mitsus, i think they do most any vehicle.
  12. FrankDrebin Guest
    Hmmm...
    Went to Motorix 2 weeks ago. Ask them if they have this "bushing" for the L200's wiper. Wala daw sila nun.
    rey's electrical sa marikina, kaya ata nila wipers. Either bushing or rotor brushes yan imho. magaling sila dumiskarte sa electric motors... from starters, to wiper motors. for directions, txt nyo si master afrasay. ako matagal na di nakapunta dun. last time I went there 1996 pa yata :D
    Jul 2004
    the best thig to do is i pull out mo wiper linkage and motor para ma tsek puro kalawang na. sayang kung malapit ang shop ko matutulugan kita.
Wiper speed not "perky" anymore...
