Results 1 to 10 of 10
    Feb 2005
    Nagpark ako sa garahe sa office then may isang kotse umalis so nagdecide ako lumipat sa pwestong inalisan nya, ang problema nung sinaksak ko na ulit yung susi ko sa susian ayaw nang umikot ng susi kahit galaw galawin ko yung manibela para sana ma-unlock man lang yung manibela. Eto nagtatanong ako sa mga ka-officemate ko kung sino may WD40 bka sakali pag na-sprayan ng WD40 eh magmilagro, ano marerecommend nyo pwede kong magawa mga paps?
    Sep 2012
    Press the key firmly hanggang maramdaman mong medyo lumubog then dahan dahan ikutin manibela
    Sent from my ASUS ZenFone 4 using Tapatalk
    Feb 2005
    Quote Originally Posted by jodski View Post
    yup i did that already sir ayaw pa din, fortunately my office mate has wd40 and i sprayed a good amount inside the keyhole and it turned smoothly, problem solved! baka nanigas na mga dumi't alikabok sa loob, thanks for the advice sir :-)
    Jan 2009
    Maybe one of the key tumbler pins got stuck.
    How old is the vehicle?
    Feb 2005
    its a corolla 1990 sir, quite old na din, you may be right tumbler pins probably got stuck because of the acuumulated dust or debris or whatever, but everything's fine now... i sprayed the keyhole with wd40, thanks anyway!
    Mar 2004
    Have it fixed / cleaned ... the problem might manifest again ...
    Feb 2005
    thanks! will do that...
    Oct 2009
    nangyari na sa akin yan..bigla nalang nag stock up ung manibela..dun sa evengelista .pag pasok ko ng susi ayaw ng mapihit ng manibela..tumawag nalang ako ng gumagawa binaklas nila.tapos parang may binarena ayun umayos naman.kaso hindi na siya nag la lock..
    instead of wd40, try contact cleaner. "it leaves no residue" that can harden again in the future.
    (sounds like an ad, but i believe it.)
    Jan 2009
    Contact cleaner will remove whatever lubrication is left in the assembly.
    It's better to use silicone spray. It doesn't leave a sticky residue and it naturally repels dirt.
Ignition key won't turn
