Results 1 to 7 of 7
March 20th, 2008 04:17 PM #1
Mga Bossing Tulong Naman Re My Accord 94 A/t.nagloloko Rpm Tumataas Bumababa Minsan Namamatay Pa Makina. Pag Mataas Rpm Yung A/t Nagloloko Rin Ang Shifting Ng Gear Umaabot Ng 4ooorpm Pero Pag Nag Normalize Rpm 2000 Rev Palang Nagshishift Na. Pinalinis Ko Na Ung Thruttle Body 2x Na Di Parin Naayos.
March 24th, 2008 07:16 AM #2
Nakabukas po ba nag aircon, radio and headlights kapag nagkakaganito? or does this happen kahit na wala yung mga mentioned above?
March 25th, 2008 08:50 AM #3
kahit hindi po nakabukas ung aircon, lights at radio nagloloko rpm. sabi po ng ibang tumingin ung mga sensors na ng servo papalitan. tama po kaya ito? rotary air control valve sensor at fast idling sensors daw po. if yes, kaya po kaya ayusin ng car electricians para maremedyohan. May marecommend po ba kayo na magaling magayos ng ganitong problem? Laloma area po ako. tnks.
March 25th, 2008 09:50 AM #4
Since laloma area ka, malapit ka lang naman sa banaue e. Dami naman po magaling tumignin dun. I suggest that you visit 2-3 shops before you make a decision. Since di naman sya related sa electricity directly, sa mechanic ka humingi ng advise wag sa electrician. Also, try to check your intake manifold, throttle body and sparks as well. maghanda ka na at least 5k para maaus problema mo agad. regarding sa sensors, try to see if you can get good surplus parts. hope this helps.
March 25th, 2008 11:44 AM #6
Tsikot Member Rank 5
- Nov 2003
- 3,848
Boy, am I glad I never bought an Ecosport!
BYD Philippines
