Results 1 to 6 of 6
- Nov 2009
- 11
February 4th, 2010 04:52 AM #1I have two cars, starex crdi and honda crv..
I'm plannnig to have a vacation kasi in cebu for 2 months or 3 months..
So yung mga car ko diko magagmit,ok lang ba naka stock lang sila sa garage.I mean na hindi sila na sstart or nagagamit?kasi wala naman ako pede utusan or pag katiwalaan para gawin yun..Ano po pedeng maging cause kapag diko sila magagamit in 2to3 months?
February 4th, 2010 11:38 AM #2
if your engine oil is due for change, have them done and check all fluid levels under the hood. if a solar or trickle charger is available, connect your battery to it to maintain the state of charge. as per the fuel, it should be okay but prevention is strongly advised to put about half a pint of fuel stabilizer in the fuel tank. the tires pressures too need to be checked and maybe overinflated by 5 psi from specs just like when the cars leave the assembly plant to prevent flat spots on your tires. nothing beats coming back and just drive your car as if you never left than needing help to get them back on the road
February 4th, 2010 12:37 PM #3
- Jan 2010
- 283
February 4th, 2010 01:45 PM #4
February 4th, 2010 11:18 PM #6
planning to keep it for 15yrs just done 10,000 km already replaced the transfer case fluid w/...
Suzuki JIMNY [merged threads]
