Results 1 to 14 of 14
    Mga peeps staying or working near CM Recto, patulong naman ako...
    I am in need of some Aluminum sheets (around 1-2mm thick), aluminum square tubes (around 2-3mm thick and an inch inside diameter), aluminum pipe (1/2" diameter), aluminum rod (1/2" diameter or a bit smaller) and the aluminum diamond plate (around 3mm thick).
    There were rumor from some friend that there is a street near or around CM Recto na merong nagtitinda ng mga ganito (importer daw ng aluminum products). Baka naman napapansin ninyo when you passby the area. Paki post naman ng address detail or telephone numbers.
    Thanks in advance.
    Apr 2003
    I pass by there sometimes, parang meron somewhere between aranque market and masangkay, that covers 3 blocks siguro.
    I'll try to check it out pag nadaan uli ako dun. Matrafik kasi dun kaya ayaw nadadaan dyan masyado. :mrgreen:
    A1 aluminum supply ata yun...sa may T. Alonzo. baba ka sa may arranque market tapos lakad ka na lang papasok sa T. Alonzo. Unang street intersection ay soler... nasa bandang kanan ung A1 malapit sa corner ng soler at T. Alonzo or Arranque. Kung di mo makita..lakad ka lang dahil maraming tindahan doon ng aluminum products.
    May mas malapit na nagbebenta ng aluminum near Mayon.
    meron din ata tapat ng aranque market...aluminum and glass yon.
    Mga peeps maraming salamat. Hahanapin ko na lang po. At least may street na ko.
    Wildthing ive already sent u a private message of my contact numbers... our family business happens to be wholesale and retail of achitectural glass and aluminum
    if bulk orders we deliver to as far as mindoro baguio n bicol... try to give me a call 8)
    Burnikin,
    Thanks will check on it...hindi siya bulk but rather some sort of specialty thing.
    Burnikin,
    I didn't receive anything from you. Can you please email the details at whyldthing*yahoo.com
    Thanks.
    wildthing,
    i also didnt received anything in my inbox
    burns,
    sory for the late reply....medyo hindi ako nakakapagsurf lately... I have an email for you sent just now (20 jun 10.23am).
    wildthing,
    didnt received anything anyway already emailed you my contact numbers you can try to call me 8-5 mon - sat
    sa corona aluminum supply sa ongpin.
    Sir alfred,
    Saan yung ongpin?
Peeps near CM Recto, I need some help...
