Results 1 to 10 of 13
- Feb 2008
- 13
February 28th, 2008 12:59 AM #1Hello people im newbie here.I recently bought a second hand lancer gti '92 meron po na isang tumingin na neighbor namin napansin nya lang kapag po inalis nya ang dip stick then ni revolution ng malakas may tumatalsik po na langis sabi nya may loss compression daw and its not normal dapat daw walang tumatalsik.Hindi naman po sya nagbabawas ng langis except for minsan meron 1 - 2 patak after namin gamitin.Normal naman po ang temperature nya kahit sa mahabang byahe at pag umaga pag nag start meron po lumalabas na tubig sa tambutso.Do you think guys may problema sa engine? Need po ng advise.Salamat po in advance.
- Feb 2008
- 13
February 28th, 2008 09:51 AM #3Thanks for the reply washburn.I checked the dip stick nasa gitna lang oil nya pero kahit malayong byahe hindi naman nagbabawas.
February 28th, 2008 10:44 AM #4
imho, its too premature to think about loose compression now. medyo madaming symptoms ang loose compression eh.
during accelerations ba, it looses power?
- Feb 2008
- 13
February 28th, 2008 11:02 AM #5Thanks po 1D4LV. Hindi po nawawala power nya consistent sya during acceleration.Medyo na bother lang kasi ako sa sinabi nya.
February 28th, 2008 11:15 AM #6
February 28th, 2008 11:30 AM #7
So the oil splatters coming from the hole where the dipstick is being removed? That hole is small and leads to the oil pan, how does oil manage to splatter out? Are you opening the oil refill cap instead? If that is the case oil will really splatter.
- Feb 2008
- 6
February 28th, 2008 11:42 AM #8Tol! unahin natin sa tambutso mo, actually sabi ng mga nakatatandang nakakaalam sa sasakyan na kapag may tubig sa tambutso pag umaga ay kunsiyon ang sasakayan mo! ika nga running condition. Ikaw narin nagsabi na tinatakbo mo sa malayo. Kaso ang problema mo meron tumatalsik, oo tama dapat hindi yan tumatalsik kapag walang dip stick. Loos compression rin I think at merong leak yan tol!..hindi naman masama ang leak..at di ka nama titirik niyan..kaso delikado dahil nagbabawas ka ng langis which might lead sa pagkatok ng makina mo....anyways mura lang naman yan pare!
pero kung di naman nagbabawas baka naman punong puno ka maglagay!tama si washburn tol!
- Feb 2008
- 13
February 28th, 2008 12:28 PM #9
- Feb 2008
- 13
February 28th, 2008 12:33 PM #10Sa pagtakbo namin ng malayo halos same level naman ang oil nya and normal temperature.When i checked the dip stick as in parang walang nabawas, napapasin ko lang yung tulo pag pinatay na makina then mga 1-2 drops lang naman after that wala na.
Meron po nakapag sabi sa kin pag wala daw breather tong makina ok lang daw na may tumatalsik kasi thats the only way out makahinga makina in this case di ko alam kung may breather nga po itong lancer GTI '92 model is there anyone there who knows?
Salamat po sa mga reply.
probably safe to buy next yr. two yrs enough time to iron out the kinks. these cars are quite...
VinFast VF 3
