Mga peeps staying or working near CM Recto, patulong naman ako...
I am in need of some Aluminum sheets (around 1-2mm thick), aluminum square tubes (around 2-3mm thick and an inch inside diameter), aluminum pipe (1/2" diameter), aluminum rod (1/2" diameter or a bit smaller) and the aluminum diamond plate (around 3mm thick).
There were rumor from some friend that there is a street near or around CM Recto na merong nagtitinda ng mga ganito (importer daw ng aluminum products). Baka naman napapansin ninyo when you passby the area. Paki post naman ng address detail or telephone numbers.
