Results 1 to 13 of 13
    Question lang po, meron po bang may alam na nagbebenta at nag-iinstall ng simota cone filter, tube at adaptor na pang carb (mistu EL 1990) na medyo malapit sa location ko (cainta, rizal). Mahal kasi nun set nag K&N 7k eh. Thanks in advance!!!
    Usually kapag ganyan case, hanap ka ng airbox adaptor para sa mga carbed vehicles. Sa Toyota kadalasas gamit yung pang Lite Ace. Carb engine kasi siya pero hindi pwedeng nakaupo sa taas ng engine yung air filter kaya may adaptor mula sa carb tapos may pipe para papunta sa air cleaner housing. Yung 22-R engine namin ganun din. Wala kasing underhood clearance for a top mount filter kaya may OEM adaptor.
    Sa Mitsu, try mo check mga L300 gas engines. Nabenta na kasi yung samin kaya hindi ko macheck ang hitsura ng carb adaptor niya.
    Pwede yung adaptor as Otep mentioned.
    I also saw one being sold sa Banawe before (plastic adapor na).
    When we were discussing this in another forum before, some say a tube and cone type adaptor isnt too adviseable for carb engines as the proper pressure the carb needs is not generated by the tube set-up.
    Jan 2004
    sir, i hope this helps:
    Team Car Center (Banawe, Q.C.)
    413-5996 / 732-3647
    look for kerwin or aileen
    Apr 2005
    bro try smt in makati..nagfafabricate sila ng adaptor. naka pizza ako na GL and nagpafabricate ako ng adaptor. as for the pressure regarding carb..wala naman masama if mag tube type filter ka. mas medyo may gain sya compare sa plato type kasi pwde mo ilayo yung pinakafilte mo sa engine unlike sa plato higop mo lahat ng init ng makina mo.
    Feb 2005
    where is smt in makati? how much?
    Sep 2005
    tama si sir otep.
    go to any toyota dealer or toyota auto supply.
    buy the elbow sa carb for the lite ace. iyung naka kabit sa carb na may screw sa gitna. baka kumasya.
    sa team car meron sila. color blue, parang silicon hose ang texture and color. pasulat mo baka pwede.
    Saw a couple on display at Pony at AutoCentro in Cubao. Php 1,500. Plastic, can be fitted to any carb.
    maraming salamat sa mga reply mga sir! Sa team car kaya nag iinstall sila?Mga magkano kaya abutin nito kasi may set ang k&n kaya lang medyo mahal and under a tight budget ako eh...:-)
    Sep 2005
    Quote Originally Posted by jag_001
    usually mga shops sa banawe installation included na. pero tanunging mo rin para sure. diy pwede din.
    Simple lang ikabit iyan. DIY mo na lang kung taga ang labor nila.
    Jun 2005
    alam ko si sonny sy sa c3 may bentang ganun kaya lang 90 isa. yan yun adaptor na pang carb
    otep: maraming salamat sa inputs sir....problema ko sir kasi may dalawang silicone na tubo na nakakabit sa stock filter nya sir isang breather at isang mas manipis na papuntang carb mismo sa bandang likod.. doon ako naguguluhanan kung saan ikakabit yon...pede kong lagyan ng separate breather pero paano yung isa??any idea how to??
    pitbullz: yung c3 ito ba yung malapit sa dencios???pag nagdala bako ng set ng tubo at filter tapos sa kanila ko kunin yung adaptor mga magkano kaya installation nila???may contact # ba kyo nila sir??
Simota Cone Adaptor for Carb
