Results 1 to 10 of 10
    parang may diperensya yung lancer pizza gls namin. it always jerks (sometimes) when it downshifts, then the N indicator flickers simultaneously when i'm on D. what could these symptoms mean? change ATF or may sira yung tranny?
    need your help guys! TIA
    Check common stuff first like fluid level and signs of leak. Also check all linkages.
    hala miko!!!sira agad!!!herhehrehr
    hmmmm..wag naman sana ele ctronic.since you said na nag fli-flicker yung N pag nasa d...parang may sabit..
    Mar 2003
    dreaded mitsu auto transmission fault? sana hindi naman. mukhang electronic yung problem kasi may manifestation na jerk along with the flickering "n" indicator. could be the brain of the ect though. hope its nothing serious and expensive
    onga eh. hassle. due na for replacements lahat ng fluids ko, e.g. engine oil, ATF, etc this saturday.
    Quote Originally Posted by ssaloon
    miks, how bout the power? kapos na rin ba, for example nasa "2" na sya? pagkaganun kasi, medyo mahina na yung tranny.
    di kapos ang power, malakas pa ang hatak, actually. kayang sumabay sa mga vti na manual kapag naka sports mode.
    sabi ng iba baka isang spring sa tranny lang kailangan palitan.
    miks, yup. may nakalas lang dun sa loob ng tranny yan, pero hindi pa sila yung actual tranny as a whole.
    ang experience ko kasi before sa invecs, pag nawalan ng hatak, may tama na yung mismong transmission.
    fafi vlad, would you know how much and how long the job would take?
    fafi miks, depends. at most, baka abutin yan ng 3 days.
invecs2/matic question
