Results 1 to 10 of 17
January 3rd, 2007 02:40 PM #1
bakit kung high speed yung VAN(4D56) ko tataas yung temp niya to middle. but kung sa city lang o traffic mga 1/4 lang.. ano kaya ang sira?
January 3rd, 2007 04:41 PM #3
January 3rd, 2007 04:54 PM #4
May turbo ba yung iyo? Di ako familiar sa engine pero if you do, maaaring umiinit yung exhaust gas temperatures and that's causing the excess heat in the engine?
January 4th, 2007 08:16 AM #5
Check the thermostat pa rin... if it's stuck, it may not be regulating water/coolant sufficiently when the engine works harder (ie higher rpms). This happened to us before, a symptom was the temp would also go up when i rev the car long enough.
BANNED BANNED BANNED
- 3,790
January 4th, 2007 09:09 AM #6nung luma ang sasakyan ko, ganyan ang sintomas pag malapit nang masira ang water pump.
- 3,754
January 4th, 2007 07:18 PM #7Yung Pajero Gen1 ko ganyan ang problema pag high rev high speed nataas up to 3/4 umiinit talaga ang makina... hindi ko malaman pano i solve hanggang sa binigay ko nalang sa relatives ko..so faw nagagamit naman ng ayos wag lang i bibirit ng husto
January 4th, 2007 07:24 PM #8
Kung sa highspeed lang, malamang water pump iyan or clutch fan. Hindi kasi nakakahabol ang mga ito kung mabagal na ang ikot nila (medyo stuck up na). Pero kung low speeds, kaya nila.
January 5th, 2007 10:12 AM #9
January 5th, 2007 10:24 AM #10
Kung bago pa WP, check your fan clutch and/or thermostat. Step by step lang. hehehe.
Try mo sa Hino Parts Specialist sa may Grace Park, Caloocan. Search mo nalang sa google maps or...
Hino 300 Series Light Truck (Dutro)
