Results 1 to 3 of 3
January 6th, 2007 02:00 PM #1
hello po sa mga expert mag ipa pa top OH ko po aksi ugn toyota 2E ng utol kow,, ano po ba an gmga parts and items to be considered in TOP OH.. and baka may backfround kayu ng estimated cost aksi 3.5k ung canvass kosa labor nila...wala pa akong background sa Parts and Items thanks and More pOwer..
January 8th, 2007 05:58 AM #2
i'm not familiar with 2e engine but usually TO cosist of checking cams if its around specs.replacing of valves,guides and seals,check and replace valve springs and retainers and most importantly checking the heads.Also replace head studs and head gasket.MIght as well check timing belt.
January 8th, 2007 09:36 AM #3
Have a compression test done first as well and determine why the overhaul needs to be done... Before, we changed piston rings, seals, t-belt, tensioners, and bearings with OEM Toyota parts (can't remember what parts exactly but the main problem we had was a busted piston ring). All-in-all we spent around 15K or so (that was 3-4 years ago).
It's better to canvass around and get parts on your own BTW, you get to save a lot on this.
Which resulted in wiring harness issues ...
BYD Philippines
