Results 1 to 10 of 15
- Jul 2005
- 122
August 22nd, 2006 07:42 PM #1Greetings fellow tsikoteers. Parang merong thread for this but i can't find it so gumawa nalang ako ng separate.
Meron akong inquiry about acceleration. paminsan-minsan lang naman mangyari but im bothered bec pag-shift ko ng 2nd/third gear, mataas na rpm(2.5) pero mabagal or matagal ang arangkada. minsan sa stop light at ako ang nasa harapan, when the light turns green aabante nako and pag-shift 2nd gear naririnig ko na malakas tunog ng engine, high rpm na and ang tagal ng response. Some say it maybe the clutch lining. I dont know. Pls help. saan din ang shop na mahusay gumawa nito. sa mandaluyong or makati area sana. My car is ae92 1.6. TIA!
- Aug 2006
- 70
August 22nd, 2006 10:10 PM #3No doubt. I second the motion. Amen.
Be ready with a new clutch assy. or clutch lining.
August 22nd, 2006 10:55 PM #4
parang sliding na clutch mo nga
prepare na ng clutch disc,Release bearing and pressure plate
para isang gawaan na langLast edited by BoEinG_747; August 23rd, 2006 at 10:11 AM.
Tsikot Member Rank 5
- Nov 2003
- 3,848
August 22nd, 2006 11:40 PM #5have your mechanic test drive it. he should be able to tell you what's happening.
- Jul 2005
- 122
August 23rd, 2006 09:47 AM #6Thanks for the replies... yep, i suppose its a sliding clutch, pero minsan lang mangyari but im still bothered. I better have it checked. siguro complete clutch assembly na palitan ko para lahat bago. what do you think? or maybe clutch lining lang. magkano kaya aabutin? Wala din akong alam na magaling gumawa nito, can you suggest some shops? Thanks again.
August 23rd, 2006 11:08 AM #7
- Jul 2005
- 122
August 23rd, 2006 01:43 PM #8musta sir? sayo ako umorder ng bendix break pads last year. kaw pa nag-deliver sa office ko sa makati. dont know if you still remember. was trying to text you again to ask for some car parts. anyway, pm mo nalang ako. tanong ko na din kung magkano complete set nun and what brand ang ok. Thanks.
- 72
August 24th, 2006 10:12 AM #9on a slightly different note, what if kung maingay ang release bearing mo ? does it have any effect sa clutch mo ? what would happen kung di mapalitan kaagad ang bearing na ito ?
- Nov 2003
- 3,848
August 24th, 2006 10:29 AM #10it will just get noisier over time and pedal feel has a tendency to get harder
I would lean more towards technological solutions instead of deputized traffic wardens, whenever...
SC (temporarily) stops NCAP
