Results 1 to 10 of 10
    Oct 2005
    i just arrived from ortigas. hinatid ko gf ko sa office. while driving home, napansin ko na there's a knocking sound sa rear passenger side of my ride. it happens usually kapag nabbrake ako and slightly kapag cornering. what causes this sound kaya? again, TIA!!!
    Dec 2003
    busted drill arm bushing?
    Oct 2005
    i really don't know...does anyone of you experienced this? hmmmm...ngayon ko lang naranasan to.
    Dec 2003
    or busted shock mount
    or dirty rear bushings lang. ganyan din yun sa akin before. ni lubricate lang ng silicon spray, nawala na.
    o baka may taong naipit sa ilalim. hehehehe. j/k.
    Anong oto? Sa Corolla pag ganun usually yung rear stabilizer link...
    Or baka naman simple muffler bracket lang.
  7. #7
    or baka may kumakalog lang sa compartment. remove all loose items at the back and observe.
    what i experienced is i heard lagitik sa passenger side and i had it inspected sa shop and it turned out that my disc brake is causing the noise. They fixed it and the knocking noise is gone.
    Nov 2003
    trailing arm bushing. pero easier kung padala mo sa mekaniko mo para masilip nya.
    Oct 2005
    Quote Originally Posted by speedyfix
    mukha ngang natumbok nyo ang problema ko sir. kasi pinagalaw ko yung trailing arm (pinakikil ko) kasi nakabukaka yung isang gulong. tama ba ang ginawa ko? kasi hindi mai-align kapag hindi kinikil yung butas na nakakapag adjust para ma-align ang gulong (gulo ba?, try ko kunan ng pic...post ko dito pag nakunan ko na. hirap pag walang lifter). yung bushings, pwede ba bumili ng bushings lang tapos ipakabit na lang sa trailing arm? at bakit kaya hindi ma-align yung isang gulong na yun? i've gone to several shops with computerized wheel alignment pero hindi nila ma-align yung isang gulong na yun. trailing arms ba ang diperensya o bushings lang. sensya na humaba ng husto.
    Oct 2005
    sir theveed, eg hatch po ang sasakyan...ok pa ang pinagkakabitan ng muffler. walang alog whatsoever.
    sir city, kakareface lang ng brakes, front and rear...i also tried removing all stuff that can cause lagutok sa likod ng car...pero wala pa rin...
    sir happy gilmore, ummmm...wala namang tao
    salamaaaat!!!
Lagutok sa likod
