Results 1 to 10 of 10
- Dec 2007
- 16
January 7th, 2008 03:43 PM #1Bkit po kaya kapag sabay sabay bukas ng aircon at headlight ang rpm ko bumababa ng 500. At kpag magstop n galing s andar bumabagsak ng 100 parang mamatay n yung makina tapos babalik ulit ng 500 kapag naka stop n. Pero kapag walang aircon at ilaw saktong 900 rpm at ang ganda manakbo. Please help thanks.
January 7th, 2008 03:51 PM #2
Use of AC: Turns on compressor -> puts load on engine (should have idle-up function though) -> RPM drop
Use of headlamps: Turns on headlamps, tail lamps, interior lamps -> puts load on alternator -> puts load on engine -> RPM drop
January 7th, 2008 03:58 PM #3
pa check mo Idle Air Controller Valve/Idle-up mechanism sir with a trusted shop.
January 7th, 2008 04:14 PM #4
Kapag there is additional load from the compressor and/or alternator, the engine should increase it's idle speed, if not, baka mamatay ang makina. Kung di tumataas ang RPM, have hour engine checked.
January 7th, 2008 04:32 PM #5
nakku mahirap patinuin yan ganyan yung sa corolla ko ngaun eh lahat ata nasubukan ko na ganun pa din buti n lang sanay ako mag drive ng manual at mabilis ang paa ko
- Jul 2006
- 52
January 7th, 2008 07:21 PM #6have your throttle body and IACV cleaned first then check if it solves the problem..
January 9th, 2008 05:55 PM #7
oo nga sir bka yun idle-up valve di na gumagana, it should engage whenever the aircon compressor starts-up to bring up the engine rpm
- Dec 2007
- 16
January 9th, 2008 06:20 PM #8Maraming salamat po s mga nagreply... Bk dalhin ko n lng s speedyfix this saturday. I have read from another thread n naayos ni mr speedyfix yung tsikot nya by cleaning the TB and iacv. Tanong ko n lng mga magkno kaya gagastusin ko s pagpapalinis nito??? Thanks
Tsikot Member Rank 5
- Nov 2003
- 3,848
January 13th, 2008 12:37 PM #9cleaning does not always solve the problem pero mga 70% of the time it does.
- Dec 2007
- 16
January 16th, 2008 03:01 PM #10Update ko lng tong thread napalinis ko n yung TB at inadjust n yung idle up s speedyix medyo di n sumasagad ng pagbagsak yung rpm ko thanks... pero bumababa p rin sya kpag sabay n bukas ang headlight at aircon ano p kayang pwede ko patignan?
no aircon no headlight - rpm 900-1000 irevolution mo ok rpm
aircon open no headlight - rpm mga 800-900 irevolution mo ok p rin rpm.
headlight open no aircon - rpm mga 700-800 at kapag nirevs mo umaabot p ng 500 yung bagsak ng rpm.
Ano p kaya problem nito? TIA
parang some of the countdown timers along taft ave manila, aren't functioning today... or am i...
SC (temporarily) stops NCAP
