Results 1 to 5 of 5
    what kaya problem? may oil sa turbo n sa hose coneected to the turbo? is this sometninh i need to worry about?
    Mar 2003
    does it somewhat look like mine? check my Turbo Oil Leak thread. been having the same problem. d kaya galing sa intake?
    Aug 2005
    xperience k jan kung hind p blowby, worn bearing ng turbine, mski rplace m dnagttagal my oil prin konti, ung bearing it serves as seal also kya pgworn n ung shaft ng turbine balewala khit ilang plit kpa ng bearing rplace turbo na, upgrade ka masmtaas na psi pra msmagand
    any idea how much? sbi ng mechanic maluwag lang daw yung mga hoses kaya nalleak....wat u think?
    Loose hose clampings would be one possibility, I've seen it on several Pajeros before.
    Try to check the clamping first.
turbo leaking oil for pajero
