Results 1 to 10 of 19
October 15th, 2007 07:56 PM #1
mga bro,
i drive a 1992 Honda Accord LX, US model and is fitted with a Denso compressor (stock).
this year alone, i've had my A/C system done 3 times by other technicians for cleaning, replacing the freon, drier, expansion valve, etc. lumabas every quarter binabalik ko sa mechanic.
last week, after my 3rd visit to the shop, nawala ang lamig. had it checked and they said that it migth be the compressor coz the peep hole of the drier is black from the oil.
they didn't want to touch the compressor coz mahirap daw ang denso parts. suggest that i replace the compressor but if i have it changed with another brand like sanden, they will have to change the bracket and fittings too.
is it worth bringing my car to denso? i did a back read on some of the other aircon threads, malayo si mang mario where i live; new owners na daw si dankee; i'm inclined to inquire with ceejay's.
any recommendations?
TIA
- Sep 2006
- 26
October 15th, 2007 09:30 PM #3hi, i have an aircon shop here in bul, tama sbi nla, pag black oil n ung comp, its better 2 replace it n, either wd surplus or brand new f u cn afford naman, jst same wd other brands, pg black oil, wla n pag asa. its better kung denso dn kbit mo, so not to tamper d original bracket n fittings. Tnx!:nod
Last edited by theveed; October 18th, 2007 at 04:27 PM. Reason: super bold text and promoting commercials :)
- Sep 2006
- 26
October 15th, 2007 09:37 PM #4pag surplus comp, including expansion valve & filter drier, flushing, r134, oil etc, it wud cost u around 8.5t, pad bnew mga 18t including ung other parts i mentioned above
October 15th, 2007 09:56 PM #5
Nice info bro. At least may idea na ako sa cost kung magppalit ako ng compressor.
Btw, baka mapagsabihan ka ng mga mods natin. Super laki at bold at sms lingo gamit mo. Di advisable kasi ito.
October 15th, 2007 10:13 PM #6
been a long time customer of their shop in makati near magallanes overpass and the one here in e. rod near tomas morato(started when they were still in banawe n. roxas st.)
medyo pricey but they do a good job, even putting back the unit tama ang salpak, i think Theveed knows the original owners in makati, the one in e rod. was their partner that set up shop on his own but still get supplies from makati. sila gumawa nung 2 hiace. yung una nagtipid ako kasi nga medyo malaki ang quote, in the end hilaw ang lamig kahit anong balik ko sa pinagawan ko, puro palusot lang yung mekaniko. so after a year of his BS, nabutas ulit yung evaporator na kinabit nya so kay denso na ako nagpagawa. ayun parang freezer na ulit yung hiace. so when i bought our 2nd hi ace at nag ka problema na aircon, sa denso ko na din pinagawa sa e rod.
mahal but you get the quality job naman. pinauwi yung parts na pinalitan, iniwan ko na lang sa kanila dagdag kalat lang sa bahay kasi.
- Aug 2007
- 10
October 16th, 2007 08:10 AM #7
Almost the same ride here pre (Accord94), bought a Surplus NipponDenso compressor recently in Banawe nsa 3500. Then pinakabit ko na lng sa trusted na AC mechanic. As of now ayus nman. Pero suggestion lang if bibili ka ng Surplus mabuti ding ipa-check mo muna sa AC mechanic bago ikabit para iwas problema. Meron din daw sa Panay St. G.Tuazon around 2500 daw ang compressor.
O.T. na din, ask ko lang kung nagpalit ka na ng 80A battery fuse. Wala ako mahagilap tsk. Thanks!
October 16th, 2007 04:58 PM #9
autofrost - thanks sa detailed info
impulzz - thanks for the advise on coolmate corp. naka email ko nga si mr vincent tagle of pasong tamo and cathy garcia of alabang branch.
isip ko nga din na sa coolmate ko dalhin para may warranty. pag compressor lang binili sa kanila and outside labor, walang warranty sa compressor.
October 16th, 2007 05:13 PM #10
Naalala ko iyong 2013 SJ Forester ng relative namin. FMC change siya ng time na nakuha sa casa. ...
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
