Results 1 to 9 of 9
    Feb 2003
    ford lynx ghia a/t 2000
    already changed the cmp sensor and maf sensor months ago
    just this afternoon the starter doesnt crank.
    battery seems ok everything works but starter (wala na kasi yung lumang threads Sad )
    suspect: cmp sensor (maybe a version2(?) defect?) but the engine has cooled down already - used it twice in the morning - home-school-stop-school-home
    and used it from home to office around 1pm.
    5pm start of problem. im now at home and gonna go back to the car, ill try to reinstall the old cmp sensor. hope some of you guys can help...
    maybe some of you experienced this
    hoping to use it tomorrow going to manila from clark
    _________________
    Well, I'd check the obvious first, starter mismo.
    Baka solenoid lang or carbon brush.
    might not be cmp sensor.... kung cmp sensor yan dapat napapastart mo pa at pwede pa umandar...
    Yup... kung CPS o MAF, dapat nag-cra-crank yun. Might be a starter issue.
    Of note, I had hard-starting issues before even when my battery seemed completely fine. These issues turned out to be a weak battery. But then again, if it doesn't crank, it's the starter mismo.
    pag nag start ka ba meron ka nadinig or naramdaman click or wala? pag wala malamang park-neutal safety switch ang sira, try mo din start sa neutral or habang start mo medyo galawin mo konti (back and forth) un shifter
    Jun 2006
    Are you sure battery is ok? !st check that the terminal lugs are tight then try starting your car with booster cables. If it starts it might be that the battery is weak. Try to leave it running for 30 mins or so to charge the battery. Or have a battery shop check your battery.
    With AT, its common for the car not to crank when the battery is weak. I've experienced this with my old car and this happened a lot when I was working for a large car rental company overseas. This is what the mechanics did and it always worked.
    Nov 2003
    probably either the solenoid lang of the starter
help: lynx wont start
