Results 1 to 8 of 8
- Oct 2008
- 6
November 20th, 2008 10:15 PM #1i have a problem with my isuzu bighorn. it's 1992 model automatic transmission.. the problem is sometimes ayaw magstart. kelangan mo pa i-neutral bago sya magstart. sometimes ayaw talaga magstart sa neutral or park. ano kaya problema nito mga bossing???
THE AUTO SPECIALIST
- Mar 2006
- 607
November 20th, 2008 11:19 PM #2may crank ba or nag ccrank ayaw mag fire -up?
no crank , check starting systems
batt voltage , 12.5v
test solenoid switch wire ,kailangan umilaw yung test light
- Oct 2008
- 6
November 21st, 2008 12:57 AM #4
pa check mo yun safety switch sa tranny. usually nasa side ng tranny yun.
- Oct 2008
- 6
November 21st, 2008 07:53 AM #5
November 21st, 2008 10:00 AM #6
It"s very low voltage/current. Look for connection in the switch itself.
Disconnect it (battery first) from the main harness and check (Ohm setting) to make sure that it is acting like a switch.
BTW: And I am far from an expert on the AT trans, but I would think that they do not have a neutral switch like a std mechanically shifted AT. It seems nearly everything about them is controlled electronically, through the ECU
- Oct 2008
- 6
- Dec 2008
- 3
December 7th, 2008 06:14 PM #8i'm not an expert nor a guru this is purely base on my first hand experience you my want to consider po...........
almost same symptoms happened on my japs troops, click sound (from relay) lang ang naririnig ko when start, short cut solution i have found out is to move shifter from P to N, starts again until one day ayaw na syang mg start kahit na move ko uli ang shifter from P to N, nag ala tsamba ako - checked the head light, a/c, horn etc bat is ok, checked starter wires ok, one by one tsek ko un mga fuses sa fuse box (below steering column) un nk lagay n "starter" yata not working but the fuse itself is ok, change new fuse with same amp but no luck pa rin, since naka pasubo nako s DIY, pinaki alaman ko na yung shifter removed the cover para malaman ko kung ano ang laman loob ng pesteng kambyong itomeron ako napansin na parang safety switch/relay na yung binanggit ni sir afrasay nasa front ito ng kambyo di ko alam ang name pero para syang relay na coil type at di nga sya ng e-engage pg ON ng susi kaya walang rev pg start....anyways, sinubukan kong galaw galawin ito make contact with the used of screw driver, ON ang susi & may kontak na (checked the starter fuse OK) tried to start the engine & presto!!!umandar uli ang problematic jap troop ko
OT: if you will ask me kung pina ayus or pina palit ko ang safety switch/relay, hindi po.... troop itself ang pinalitan ko dahil sakit ng ulo at bulsa ko sa kaka pa ayus not to mention ang hirap pa mg hanap ng piyesa..... not worth on keeps & daily drive
They replaced it with flashing green light prior to turning yellow. I guess it simplifies things?...
SC (temporarily) stops NCAP
