Results 1 to 8 of 8
    Oct 2008
    no crank sir. all i can hear is a clicking sound from the relay.
    pa check mo yun safety switch sa tranny. usually nasa side ng tranny yun.
    Oct 2008
    Quote Originally Posted by afrasay View Post
    thanks sir.. narerepair ba yun or kelangan talagang palitan na. kung papalitan... magkano kaya? and san to mabibili sir?
    May 2007
    It"s very low voltage/current. Look for connection in the switch itself.
    Disconnect it (battery first) from the main harness and check (Ohm setting) to make sure that it is acting like a switch.
    BTW: And I am far from an expert on the AT trans, but I would think that they do not have a neutral switch like a std mechanically shifted AT. It seems nearly everything about them is controlled electronically, through the ECU
    Oct 2008
    Quote Originally Posted by v6dreamer View Post
    wow! thaks a lot v6dreamer
Help: Isuzu Bighorn won't start
