Results 1 to 4 of 4
March 31st, 2007 11:36 PM #1
Good evening peeps.
I would like to ask pano malalaman kung sira na po ung IACV ko or (throttle body ba tawag dun)?
Meorn ho bang diagnostic check para malaman kung sira na ito?
How much po kaya ito? baka meron po kayong kakilala ng second hand at reliable if diagnosed na sira nga po ito?
sana may makapag advice
thank you.
Tsikot Member Rank 5
- Nov 2003
- 3,848
April 5th, 2007 12:14 AM #2for what car? normally busted na yan once di na tumataas rpm mo when you engage the a/c
April 5th, 2007 08:54 PM #3
Thanks boss speedy. Actually ako ung nagpagawa sa inyo last sunday, cleaning lang ng throtlle body nga po ba tawag dun? pero di binaba ung intake manifold kasi wala ng time at medyo malinis naman po ung loob. Sir kanina bago ako umuwi, namatayan ako engine di ko alam kung bakit then when i tried to restart nag iilaw ung check engine light, bagsak ung rpm up to 100 pero nun huminto ako sa shell magallanes sumobra naman taas at erratic na parang sama pa ng ugong. Sir pag umilaw po ba check engine light (code 14 = IACV) eh siguradong palit na po ba un? or meron pang pwedeng gawin kasi medyo mahal ata un and ala pa ako budget, bakla magarahe lang oto ko po eh.
Advisable din po ba bumili ng 2nd hand? surplus? do you know reliable source?
please advice kasi mas mahal pagnasunog ecu po di ba?
- Nov 2003
- 3,848
April 5th, 2007 09:22 PM #4hindi naman basta lumabas yung cel na sunog box mo. try mo palitan muna iacv mo then kung nandyan pa yung ilaw then defnitely tinamaan na box mo. i think i mentioned it rin to you before nung nasa shop ka right?
surplus box might cost between 7-8k. repair is slighly cheaper iacv na surplus nasa 1500-3k.
VinFast VF 3
