Page 1 of 2 12 LastLast
Results 1 to 10 of 13
    Feb 2006
    helo mga sir and mam. nabasa ko po yung thread bout grounding kit pero di po ako maka relate coz I'm just a newbie here. HEHE para san po ba yun and is it necessary to put that in my car. tagal na po ako may car but i only got interested bout cars medyo 6 months pa lang.
    TIA
    Apr 2005
    a grounding kit maximizes efficiency of all stock and aftermarket vehicle electrical systems. This results in smoother, more efficient engine operation, better electrical component performance (ilaw, busina - kung naka stebel ka hindi mag dim ilaw mo.., etc).
    Feb 2006
    Quote Originally Posted by tunasashimi
    san po ba dapat ilagay talaga yung mga wires?
    Jan 2004
    Review the old threads meron dun diagram sa first few pages.
    Eto may actual pic: http://tsikot.yehey.com/forums/showthread.php?t=15511
    Eto may diagram: http://tsikot.yehey.com/forums/showthread.php?t=15402
    Eto rin may grounding kit: http://tsikot.yehey.com/gallery/show...cat/500/page/5 kaso ang kita lang yung from the battery terminal tsaka yung sa makina.
    IMO if you have a less than 5 year old stock car, putting grounding kits will only be a waste of money.
    IMO it's only beneficial for older cars or cars with a heavily modded sound system.
    my 2.
    Feb 2006
    thanks wildthing tinignan ko na yung diagrams and I think medyo madali lang gawin. I will make it my self and give you guys feedback kung meron ngang improvements. thanks again
    Feb 2006
    i think i will benefit from this artpogi kasi my car is 96 lancer itlog but m the first owner. w8 yung car ko pag sa umaga and malamig ( I live in Baguio) medyo kailangan mo pang apakan yung gas para mag start pero hindi naman mahirap mag start but pag nag start na kailangan apakan mo parin yung gas para hindi mamatay yung engine medyo hndi kaagad tumatas yung rev nya yung para bang nalulunod pero pag malamig lang yung engine. can you help me guys to slove this medyo irritating kasi.
    Aug 2004
    *rage: before you spend on grounding kits, have your throttle checked. Kung EFI car mo, might be a clogged vacuum line that starts flowing when warmed up. Kung Carb, try some carb cleaning, and lubricate your idle-up.
    Quote Originally Posted by artpogi
    my 2.
    Actually, grounding kits have been proven to work on brand new cars, too. Especially electronic throttle cars like the Mazda3. But they need to be tuned and adjusted (i.e.: grounding points moved here and there) for maximum effect. And since dyno-tuning is rather expensive, medyo not worth it to tune them.
    But if there's a commercial kit for your car, and someone's already mapped out the optimum ground points online... why not?
    Feb 2006
    carb yung car ko niky.Is using a carb cleaner na spray enough for carb cleaning o dapat ko talagang patangal sa mechanic? and pano yung lubricating the idle up? pasensya na medyo bobits talaga ako sa car e
    Quote Originally Posted by rage1018
    It's better to have the carb removed. When using a carb spray, where do you think will all that dirt go?
help! grounding. for what?
