Results 1 to 5 of 5
    hi mga sirs hirap ung auto ko magstrt pagmalamig ung makina. posible kya mahina n ung batery? then pag in on ung a/c nahina ung headlights ko. thnks guys
    Did this happen just recently? If yes, then most probably, the battery is the culprit. Have it load-tested in the nearest battery shop. Good luck!
    3909:trampoline:
    thnks fr the reply. mga 2 weeks na. pna chek ko s batery shop sbi mababa n rw ung amperes. pero nung pnachek ko s nag rerepair ng batery malakas p dw. mga 1 yr n ung batery.
    how long have you been using your battery?
    tingin ko battery din lang.
    Jun 2006
    Most likely battery yan. To check, just borrow another battery and switch it.
start problem
