Page 1 of 2 12 LastLast
Results 1 to 10 of 12
    i recently acquired a second hand suzuki carry mini van. problem is may kalampag / humming sound (parang may humahampas not high pitched) na maririnig whenever the van is in motion. kapag bumibilis, bumibilis din kalampag. mas malakas kalampag kapag pahinto galing high speed.
    i've had the vehicle checked at servitek timog. diagnosis was broken wheel bearings of the front wheels and axle bearings of the rear. was quoted around 6,500 pesos. i had the bearing replaced at G araneta for only 4,200. the brearing replacement however did not solve/eliminate the humming sound.
    i brought the van to a shell service station along kalayaan ave q.c. tire rod and bearing were diagnosed to be ok.
    baka po meron na sainyo na may parehong experience. hingi po ako tulong kung ano problema and kung ano pwede ko gawin. salamat.
    Dec 2002
    have you checked the muffler support ? or even the front bumper ? baka may loose bolt that is making the sound. Can you specify which part of the van ?front or rear. baka loose seat bolts
    hindi ko pa nacheck. check ko mamya then balitaan ko kayo. salamat sa info.
    Aug 2005
    uhmm.. madami kasi bearing bro..
    naka a/c kaba?
    try mo mag cruise say sa 4th gear then put it on neutral see if nawala yun humming sound. pag nawala sa tranny yan, pag hindi sa axle bearings. check mo engine support. ganyan din yun samurai (suzuki pa rin :D ) ko nun nakuha ko. puro kalampag at ugong. palit lahat ng front axle bearings and engine support. ngayun tahimik na siya pag idle. pag cruising yun free flow muffler nalang madidinig mo.
    sira ac ko. kumpleto lahat ng aircon accessories except for the compressor fan belt. papacheck ko pa kasi kung magkanu and ano yung gagawin sa aircon. sir finchy18, ano pa mga bearing na pwede cause ng kalampag?
    thanks sir afrasay. mukhang hindi sa tranny. natry ko na kasi yung test na suggest mo. lalo lumalakas ugong kapag nagnuetral na at pahinto. sa high speed medyo nawawala. baka nga engine support or loose bolt connection ng bumber or muffler. check ko mamya and balitaan ko kayo. saan nyo pala sir pinagawa yung samurai nyo noon? mahirap kasi maghanap ng shop na magaling gumawa at mapagkakatiwalaan e.
    check mo crossjoint yun sa tranny and sa diffs.
    sa cousin ko sa obrero area.
    sure na yan. cross joint yan.
help on eliminating annoying sound
