Page 1 of 2 12 LastLast
Results 1 to 10 of 20
    Sep 2005
    it's time to replace my sparkplugs.
    may nagsabi sakin maganda raw cold sparkplugs ikabit ko.
    ano ba mga magandang brand and model?
    ung platinum tip din pla dapat
    paki indicate na rin price at san makabili
    tnx
    Jun 2004
    If your engine is unmodified, stick to what your car manual recommends. Usually NGK or Denso.
    Quote Originally Posted by kenet_3
    tnx
    cold plugs are typically used when the engine is a high reving turbo charged engine.
    Using cold plugs in a stock non-turbo engine will just result in fouled plugs when driven in daily traffic.
    for the 323... the manual states that you can either use a cold or hot sparkplug.
    ok ang cold plugs kapag lagi kang nasa highway / long drive. pero kung city driving ka... dapat hot plugs.
    and kapag nag foul-up ang cold plugs, talagang ramdam mo.
    Sep 2005
    may nagsabi kasi sakin na cold sparkplugs, meaning yung higher heat rating (tama ba?)
    kasi naka-advance ang timing ko and may engine knock. cold spark plugs daw ang solusyon dun para di mag-knock
    Double post...
    Cold plugs help in curing knock in advanced timing but it's not a necessary item.
    What fuel do you use? If you advance your timing its adviced to use high octane like Petron Blaze or Velocity... or your timing is just way too advanced.
    Check what your stock plug is and get the next heat range... for example if you're using an NGK BKR5E, switch to BKR6E.
    mag Bosch Platinum ka na lang. Yun orig ha. may 4 tip platinum na dito pero medyo mahal.
    me, i'm using denso iridiums. but my engine is turboed. so best stick to OEM spec.
    Sep 2005
    Quote Originally Posted by vinj
    BKR6E na ung rating ng stock plugs ko e, and wla na daw higher pa dun (ung BKR7E, o meron ba talaga nito?)
    so i guess stick na lang talaga ako sa rating na un?
    pero may nakita rin ako sa mga bosch plugs, may counterpart yung BKR6E na platinum tip. ok kaya un? ramdam kaya difference? P130 per piece lang kasi e
HELP. cold sparkplugs
