Results 1 to 10 of 39
September 29th, 2007 10:14 AM #1
im driving a honda ESI... when i was driving biglang na notice ko na parang flat ung likod then i checked hindi naman flat. pagtingin ko sa isang reflection ng building hindi umiikot ung rear right tire ko na parang feeling mo naka handbrake pa rin... may ingay sya buti na lang malapit pa lang ako sa bahay and i was able to make it home... ano po kaya possible problem? thanks guys
if you can also estimate kung magkano damage... ty
- Nov 2006
- 299
September 29th, 2007 10:52 AM #4could be brake related problem at isa dyan ay frozen wheel cylinder if drum brakes or frozen caliper piston if disc brakes.try mo muna ibleed kung saan yung wheel na hindi umiikot.have somebody to slowly press the brake pedal 3 times and hold,and while holding the brake pedal ikaw naman ay dahandahan mo rin iopen ang bleeder valve na nasa likod ng backing plate kung saan nakamount yung brake mechanisms na nasa likod din ng wheel assy. kahit di mo na tanggalin yung gulong or kung saan ka komportable,tingnan mo kung magsquirt ba yung brake fluid.kaya mong gawin ito.
September 29th, 2007 11:30 AM #5
pilit sya umikot e... at first hindi talaga umiikot tapos napapaikot ng konti den stucked pa rin na maingay..
- Jul 2003
- 573
September 29th, 2007 12:13 PM #6malamang na stucked up na ang brake wheel cylinder,or ayaw ma-release ang hand brake. best thing to do is remove the tire, remove the brake drum or caliper assembly (which ever is applicable to your ride) and try to turn the
axel assembly by hand. It should turn easily without the brake drum or caliper.
If not, then you have a stucked up wheel bearing.
September 29th, 2007 12:26 PM #7
gaano na kalayo ang na drive mo before mo napansin? I think pag stock up iikot pa rin pero meron "thug" or tunog na malakas ka maririnig...and matagal ba hinde nagamit yun car mo?
September 29th, 2007 12:42 PM #8
ginamit ko lang kagabi pero kanina nung sa stop light na inclined nag hand break ako tapos parang feeling ko di nagrelease e... pero how come isa lang di imiikot? di ko pa kasi pansin kung pati ung isang rear tire di rin umiikot basta maingay sya... ginawa ko pinagapang ko ng mabagal til makauwi muna mga 200 meters
September 29th, 2007 12:55 PM #9
I'm not an expert pero tingin imposible di umikot dahil yun eh kasi ma force syun tire na umikot since round ang shape and yun power na pag accelerate, parang pag i-tow ng kahit naka hanbrake umiikot pa rin yun mga tires diba? anyway, pa check mo na gad siguro sa mechanic mo...habang konti pa lang sira...
September 29th, 2007 01:24 PM #10
umiikot tapos stuck up tapos ganon lang... pero kung hand break naman un dba iikot din un?
parang some of the countdown timers along taft ave manila, aren't functioning today... or am i...
SC (temporarily) stops NCAP
