Results 1 to 8 of 8
    Jan 2003
    hi guys, good day to all...i need your help.yesterday my radio antenna fu__ed up. it doesnt extend anymore, and its motor is constantly running so i have to disconnect it live cable...Is it repairable? if not, how much does a replacement cost? thanks in advance.by the way, the ride is 97 civic.
    Hirschmann (OEM Mercedes) costs about Php 1,500.00 for the whole assembly.
    Taiwan brands can go as low as Php 600.00 during carshows (whole assembly also).
    OEM Honda will probably be more expensive than either one.
    Sometimes it's just the mast or plastic cable that is broken. This can be repaired by your not-so-friendly Banawe freelancer for around Php 500.00/ea.
    Jul 2006
    Agree, the mast cable usually breaks. Do you still hear the motor running? If so, then just replace the mast.
    yup, usually it's the plastic rack gear that is cut. that's the long plastic cable with gear teeth. if you're on a budget just go to banawe and ask the "mechanics" there to fix it for you. last time i had mine fixed it cost me P400, but the antenna does not extend fully now as some length of the plastic rack was lost.
    Sep 2005
    Doc Otep, saan makakabili ng Hirschmann? That I like! :D
    Most no-brainer place would be BLADE. Malapit lang kasi SM dito sa amin. hehehe.
    Sep 2005
    Thanks Doc!
    Oct 2005
    since sinabi mo that the motor is working, malamang putol lang yung plastic na mukhang beyblade rod. ganyan din nangyari sa 626 ko at Sentra SS ng cousin ko. pag binaklas mo yan, parang ganito ang makikita mo.
    yung color blue yung sinasabi ko.
    pinaayos namin yung Sentra SS (B13) ng cousin ko 250petot lang sa banawe.
    http://www.kotse.com/forums/index.php?showtopic=12406
    this thread from the other board might be helpful.
Motorized Radio antenna....
