Results 1 to 10 of 11
May 29th, 2004 07:44 AM #1
Mga bossing,
kindly evaluate my problem and give your recommendations kung ano dapat gawin:
Problem 1:
White Smoke: been experiencing this for the past few months. Ang lakas ng usok pag humahataw or idle tapos ni rev mo...
Problem 2:
Squeeking brake sound: Had my disc brakes refaced but after a few weeks bumalik ulit yun sound...
Proposal:
Kailangan na b ivoerhaul ito pag white smoke or pede top overhaul lang muna?
How much does a general overhaul cost? top overhaul?
What usual part do i need pag top overhaul and san maganda bumili aside sa casa?
Please advise. Thanks in advance.
May 29th, 2004 10:00 AM #2
I suggest pa overhaul mo na, and todo overhaul, hindi lang top overhaul. Hindi ka kasi nakakasigurado sa top overhaul lang. (unless valve problem lang).
General overhaul ko dati P4000 siningil ng tropa ko for labor, yung parts mga 10k ata.
yung sa brakes naman try replacing the pads.
May 29th, 2004 01:23 PM #3
White smoke ibig sbihin oil yan, try mo palitan piston ring and valveseal. if you want genuine parts dun ka sa mitsubishi megamall buy mas mura cla kesa casa. Sa brake replace mo ung pads at tingnan mo kung kumpleto pa clips .
June 3rd, 2004 10:37 PM #4
1. white or blue smoke? steam ba lumalabas or talaga smoke as in oil burning?
kung steam must be a head leak on water jacket kailangan palitan ang cyl. head gasket. pero kung oil smoke malamang piston rings. depends kung ano ang kailangan ng kotse mo.
pag head gasket lang kahit ikaw kaya mo na yan. pero kung yung later well ipa o/h mo na
2. squeeking sound , kung bago pads mo try putting slots sa pads by sawing grooves in it, this will cool the pads down a bit. also dont forget to put anti rattle (shims at back of pads)
June 3rd, 2004 10:37 PM #5
June 3rd, 2004 10:37 PM #6
June 5th, 2004 06:29 PM #7
squeeking?lalo na pag kumakabig baka na stuck ung pad sa rotor maybe corroded pag stuck up need overhaul pares caliper>>
White Smoke if bago lang baka sobra lagay langis or every morning lang ba >>
June 5th, 2004 07:27 PM #8
what happened to using question marks and periods?
please use proper punctuation marks. thanksLast edited by ssaloon; June 5th, 2004 at 07:34 PM.
Tsikot Member Rank 5
- Nov 2003
- 3,848
June 6th, 2004 02:54 PM #9maveric, just text me if we're on for the overhauling on wed. once matangal yung head we will be able to tell you what needs to be done and also give the pistons and rings a better once over
thanks!
March 15th, 2010 04:13 PM #10
I am having my Mitsubishi Galant '91 GTI top overhauled since yesterday. Labor costs PHP4,000. Will know later from my dad on how much the parts (gasket, piston ring, etc) costs.
^ Ako I just use the good ole mini elm327 OBD2 scanner. Pero usually sa long drives ko Lang...
