Results 1 to 5 of 5
    Oct 2003
    may nagdedevelop na rust sa ilalim ng upuan ko yun mga frames ng seat that hold the seat and the body together.
    without painting the metal, paano ko ma minimize or neutralize yun rust?
    nag try na ako ng WD40 ba yun kso ayoko nun amoy nya talaga ksi naiiwan sa kotse mabaho.
    pwede ba oil? wat brand maganda?
    other chemicals na mabibili sa hardware or car shop meron ba ??
    thnx
    first alisin mo ang rust
    steelbrush it with a little metal conditioner or rust converter...then i paint mo ng epoxy primer or epoxy zinchromate or epoxy enamel.
    Feb 2005
    Before, ganyan ginagawa ko sa ride ko nung kalawangin yung hinge ng pinto. Masakit sa ilong yung amoy ng oil at saka di ako panatag. May baby pa naman kami nung time na yon.
    IMO, ang kalawang, babalik at babalik kung anong remedyo lang ang gagawin. Besides, magiging daily or weekly maintenance na rin sa yo yan. It would be better kung papinturahan mo na para wala ng abala. Make sure na tanggalin muna yung kalawang bago pinturahan.
    Kung di mo pa papipinturahan, try mo kaya grasa, yung blue ang color.
    Apr 2004
    i had a rust spot on my roof because a dent exposed the metal. i sanded it a little, then painted over it with the same color for protection. tama ba ginawa ko o kailangan epoxy primer talaga? otherwise, it looks fine naman.
    correct, rust converter. try the brand name "Ospho" if you can find it. chip out the excess rust with a scraper or wire brush, apply rust converter then after the color turns black (after about 30 minutes) you can paint over the treated part.
    kung wala ka makita na rust converter then you have no choice but to wire brush the affected area until all you see is shiny metal, then apply cold galvanizing paint (may nabibili nyan sa ace, "Zinc-It" ang name. just one thin coat. let dry for a day before applying paint (preferably spray paint, don't use a brush).
    pwede din aluminum paint kung wala ka makita na "Zinc-It". but aluminum paint does not prevent rust from starting up again if you miss a rusted spot. zinc will since it has galvanizing action.
    is the affected part the rail where the car seat slides for adjustment? then the best is to apply a thin coat of grease. see if you can find the electrical insulation grease (it does not smell!). color is transparent so it does not look like grease. it's made by Dow Corning, in a green box and green tube (parang sa toothpaste). O-ring lubricant also works very good (parang transparent grease din yun, made also by Dow Corning, so green box and green tube). it also does not smell like ordinary EP2 grease do.
Rust Help!!
