Results 1 to 7 of 7
    May 2005
    may nararamdaman ko din sa steering wheel ko (tok-tok).
    kapag nagbbrake ako,tendency mapupunta stress sa harap (tok) then gas ulit strees at d rear(tok)...... brakes, stress at front (tok) gas ulit,stress at d rear(tok) and so on... pero sa steering lang naririnig ha.
    dinala ko sa casa sabi palitan ko mga to:
    -ball joint LH & RH
    -Upper arm FR & RH
    -Stab bushing L&R
    -Stab Link L&R
    -String boot
    napalitan ko na. pero hindi na sa casa. then...
    nawala pansamantala mga 1week then bumalik nanaman. napansin ko kapag lumalamig yung makina nawawala. then kapag nalulubak nnaman babalik. kapag lumamig wala nanaman. hirap hanapin, kailangan ko pa magstroll muna ako para lumabas ang toktok. kapag medyo lumamig nawawala naman.
    what needs to be replaced talaga.. ty
    Dec 2003
    tie rod end maybe, also check your engine support.
    CV joint needs replacing when you hear constant clicking sound when turning, especially turning while going uphill.
    Feb 2006
    patignan mo nadin ang Suspension Am Support... natangal yung saken...
    CVJoint naman ang sakit ko ngayun...
    Jul 2005
    Tama pa-check mo yung engine supports mo pati na rin yung steering column bushing.
    May 2005
    napansin ko may minimal totok tok din kapag steer ko steering wheel from left to right from stop. so rule out ko na front suspensions, bushings, etc...? baka steering column bushing? sugest pa kayo posible sira para sasabay ko na pa-check. ty
    Aug 2005
    bushings and engine support Try to check
    Nov 2003
    have it diagnosed muna ng tama before replacing anything else.
Balljoint Or Cv Joint, lagutok sa harap(ilalim)
