Results 1 to 10 of 10
- Jun 2005
- 9
June 27th, 2005 11:19 PM #1mga pare san ako makakabili ng turbo kit na medyo mura o kaya ung surplus pls help me tnx
June 28th, 2005 08:34 AM #2
if you're gonna run a custom turbo, you will have to run it on low boost only with the stock internals of the 4G92 because of the high compression ratio. kung satisfied ka na sa low boost, go for the custom turbo! but if you're a boost addict, i think an engine swap is the route for you.
have you considered the 2nd gen 4G92 MIVEC DOHC? bolt on sa pizza lancer siya, good for around 160-165hp, stock.
try visiting www.mymitsuph.com or www.mitsulancerph.com for more infoLast edited by ssaloon; June 28th, 2005 at 09:05 AM.
June 28th, 2005 10:15 AM #3
Originally Posted by pherdee
June 28th, 2005 10:21 AM #4
There's a Pizza turbo kit for sale on MLPH: http://mitsulancer.proboards22.com/i...8680787&page=1
June 28th, 2005 11:38 AM #6
Not to mention the added maintenance that comes with it :D
You have plans to upgrade your brakes too I presume? ;)
June 28th, 2005 11:44 AM #7
normal maintenance lang naman sa turbo eh. just make sure to change oil every 4-5k km. also, you have to get the necessary gauges and engine management goodies.
- Jun 2005
- 9
June 29th, 2005 04:18 PM #8maasahan tlaga kyo mga kapatid maraming salamat sa inyong laht!!!!!!!!!!!!!!!!!!
June 30th, 2005 09:41 AM #9
saw this ad * mymitsu:
RS works TURBO KIT for 4G92 sohc 97-2002 lancer - 42Kneg
slightly used, garrett t25 turbine, cast iron exhaust manifold w/ heat shield, RS works intercooler, BOV, stainless steel mandrel bent pipings, additional injectors w/ controller. COMPLETE bolt-on TurboKit for your PIZZA
call: 09173272642
- Jun 2005
- 10
June 30th, 2005 03:36 PM #10There is a shop along 7th ave. kalookan that sells turbos. they dont install though. If you come from C3, turn to Serrano and make a left turn at 7th ave.
