Results 1 to 7 of 7
November 12th, 2007 12:12 PM #1
Good day,
Ano po ba ang best way para makatipid sa gas consumption? Currently, nasa 5 - 6 km/lit ang konsumo nya. BTW, the car is a corolla XL 97 (stock gli 1.6L engine).
Nasa adjustment kaya ng computer box??? di ko lang alam galawin yun kasi carb lang ang alam kong galawin eh.
BTW, san kaya maganda magpa-tune-up w/in mandaluyong area?
Thanks!
November 12th, 2007 12:53 PM #2
XL Corolla has no computer box since it's a carburetor system.
Basic stuff first, full tune-up, replace worn distributor caps, plugs, filters etc... Check tire pressure...
Might wanna search about maximizing fuel efficiency as well.
November 12th, 2007 01:14 PM #3
Welcome to Tsikot hammerdin!
You can also check out these threads for your inquiry:
http://tsikot.yehey.com/forums/showt...ow+to+save+gas
November 12th, 2007 01:48 PM #4
November 12th, 2007 08:04 PM #5
*hammerdin
sir ilan po dati average consumption nyo Kilometers/Liter?
pasingit na rin po kung ok lang...
ilang average kilometers/liter ang tinatakbo ng EFI engine na 1.6?
November 13th, 2007 09:43 AM #6
bka xl with gli engine yung oto mo? if EFi sya, try mo i reset yung ECU.. ewan ko lang kng parehas sya sa honda pero ganito ang procedure..replace sparkplugs or cleaning, pati air cleaner palitan mo na rin and check fuel filter bka marumi na rin.. painitin mo muna yung engine tapos turn off then remove the ECU fuse for at least 1 min. then kabit mo ulit, start the engine pero wag mo tapakan ang gas para magsset yung ECU sa desired setting. hayaan mo lang nka idle for 1min or more then turn off. tapos start ulit, pwede na tapakan ang gas.. hope this works for you
November 13th, 2007 11:52 AM #7
yup. corolla XL with gli engine po. before it was 7-9 km/lit.
anyway, thanks sa reply. i'll try to do that.
Exactly! It’s an exciting time — more affordable and practical EVs are definitely on the way.
Audi will no longer develop new...
