Results 1 to 10 of 10
    Jun 2005
    mga pare san ako makakabili ng turbo kit na medyo mura o kaya ung surplus pls help me tnx
    if you're gonna run a custom turbo, you will have to run it on low boost only with the stock internals of the 4G92 because of the high compression ratio. kung satisfied ka na sa low boost, go for the custom turbo! but if you're a boost addict, i think an engine swap is the route for you.
    have you considered the 2nd gen 4G92 MIVEC DOHC? bolt on sa pizza lancer siya, good for around 160-165hp, stock.
    try visiting www.mymitsuph.com or www.mitsulancerph.com for more info
    Quote Originally Posted by pherdee
    I would not really put together "mura" with a turbo job IMO... you may end up spending more in the long run.
    Aug 2004
    There's a Pizza turbo kit for sale on MLPH: http://mitsulancer.proboards22.com/i...8680787&page=1
    be prepared to shell out around 30-40k for the custom turbo.
    Aug 2004
    Not to mention the added maintenance that comes with it :D
    You have plans to upgrade your brakes too I presume? ;)
    normal maintenance lang naman sa turbo eh. just make sure to change oil every 4-5k km. also, you have to get the necessary gauges and engine management goodies.
    Jun 2005
    maasahan tlaga kyo mga kapatid maraming salamat sa inyong laht!!!!!!!!!!!!!!!!!!
    saw this ad * mymitsu:
    RS works TURBO KIT for 4G92 sohc 97-2002 lancer - 42Kneg
    slightly used, garrett t25 turbine, cast iron exhaust manifold w/ heat shield, RS works intercooler, BOV, stainless steel mandrel bent pipings, additional injectors w/ controller. COMPLETE bolt-on TurboKit for your PIZZA
    call: 09173272642
    HTH
    Jun 2005
    There is a shop along 7th ave. kalookan that sells turbos. they dont install though. If you come from C3, turn to Serrano and make a left turn at 7th ave.
finding a turbo kit for 4g92
