Results 1 to 10 of 11
September 3rd, 2007 08:23 PM #1
is a/c belt and fan belt the same?
kasi sa friend ko maingay yung parang squeaking sound. then sabi ng kapitbahay namin fan belt daw yun.
tapos sabi ng friend ko this month, kakapalit lang ng a/c belt, timing belt at alternator belt.
so saan dito yung fan belt? or iba pa yun? thanks!
September 3rd, 2007 08:32 PM #2
lahat naman yan fanbelts. at lahat yan pwede mag cause ng ingay. patakan nya kamo tubig kada belt. para malaman nya kung alin dun ang dapat palitan uli.
- Oct 2004
- 278
September 3rd, 2007 09:07 PM #3Nakasanayan lang pong tawagin na fan belt yun dahil sa mga RWD drive cars, belt driven yung radiator clutch fan...
Depende po sa design ng pulleys ng car, pwedeng magkakahiwalay ang belt ng clutch fan, water pump, alternator, A/C compressor, and power steering.
Pag nag-ssqueak, maaring maluwag yung belt, kalbo na yung traction nya, or pwedeng may stuck na bearing...
BTW, ok lang basain ng water, but do not spray lublicants to your belts... lulutong at iigsi ang buhay ng belts...
September 3rd, 2007 09:14 PM #4
so this means? since napalitan nalahat ng belts. wala na akming papalitan? hehe kabado si kaibigan eh. yaw na magbayad ulit.
September 3rd, 2007 09:16 PM #5
ay baka makatulong. twice pa lang daw nagnyayari and both kapag hirap yung engine and naka ON yung aircon. thanks. so ano kaya yun?
- Oct 2004
- 278
September 3rd, 2007 09:35 PM #8
kasi po pina over all check ng friend ko yung makina. so yun lang po ang mga binangit n kelangan palitan. so hindi po ako sure kung pulley nga.
soano po dapat gawin namin?just wait? yun lang? thanks!
September 3rd, 2007 09:44 PM #9
hmmm, kung alahat bago na and tama naman tension ng belt baka nga yong bearing na yon ng pulley.
September 3rd, 2007 09:49 PM #10
ay! pwede po ba na tension bearing ang problem? i think kelangan daw po yun i-replace pero kapos sa budget kaya sabi next month nalang. thanks!
Dito pala nasagot na din "feri" meaning. Sedan nga. hehe
What's a Ferio?
