Page 1 of 2 12 LastLast
Results 1 to 20 of 34
  1. #1
    ano kaya problem ng car ko, pag low gear sya, hindi pino ang rolling nya from stop, nagje-jerk eh. kaya linalaro ko yung clutch para ayos ang start...or from 1st gear...pero afterwards ok naman. thanks for the input!
    Dec 2003
    I have a similar problem. It does not happen everytime, it happens normally when I have used the clutch a lot. One of the possible cause is uneven wear of clutch. Worse case may warp or crack ang flywheel, pero unlikely daw iyon.
    Ito nga ba talaga ang cause? Also what if hindi pa naman nag slip ang clutch ko. Should I already look into replacing or having my clutch already serviced because of this. Or just wait until the clutch wears out?
    jkyamog,
    The fact that hindi sliding clutch yan...baka hindi nga clutch....but that would be difficult to assess....if I were you, having the clutch checked would be a better option than getting stranded because of a faulty clutch (magkano ba mag pa-tow at an cost ng abala sa tumirik na sasakyan).
    Philpogi,
    Does your car have engine rev problems at idle? Kun meron din at ito ay carburated engine, it could be dirty carbs....baka me konting bara ang carb jets....try carb cleaners and some oiling of the carb mechanicals too.
    my 2 cents. hth
    Dec 2003
    thanks. i will try to have my clutch checked. although it does not happen always. I am actually trying to look for other spots of the problem. yung ba mas madali galawin tapos ibalik if nothing happens.
  5. #5
    Fuel injected ang engine ko eh, and the jerking just happen at very low speed. Parang ang hirap timplahin ng clutch. At mid to high speed no problem naman. The problem is kakapalit lang ng clutch disc ko mid last year. I am not a clutch driver too. Naku ano kaya sira nung akin?
    Nov 2003
    if you feel na yung clutch yung sira then dapat palitan na. minsan kinakain nya rin yung flywheel which sometimes has to be refaced. this will only add to your costs and can be avoided with earlier maintenance.
    Dec 2003
    saan ok magpacheck and gawa ng clutch? Sa akin is local terrano. kung sana puwede ay malapitlapit sa south. one option is Nissan Westgate, pero ang alam ko Nissan casa is not that good. Actually I would rather prefer hindi casa, not because of the cost. Kasi sa casa at times you can't see what they are doing. malas mo lang kapag ojt pa ang nag service sa car mo.
    I can source out the parts, likely available naman iyan sa Advance sa pasay. Pasay area for me is ok too.
    speedfix do you do clutch service? if you do please pm me the labor charge. thanks.
    Nov 2003
    yup, we do tranny replacements i'll pm you now!
    Feb 2004
    palyado ba siya baka madumi lang ang injectors mo o kaya kailangan magpalit ng fuel filter
  10. #10
    fuel filter....every kailan ba ang palit? hindi kaya eto nga?
    Dec 2003
    sa akin I tried to advance the timing myself. It seems to have greatly reduced the jerking almost gone, pero there is still some. I have still observe though, 1 day palang ako nag drive. So baka nga hindi clutch ang problem. Pero I am not yet ruling out if clutch ang problem. I have already canvass the parts both orig and replacement and labor. Para mabudget nga if talaga clutch ang problem.
    Feb 2004
    If i were you palitan mo muna yong fuel filter mo (i think k40000miles im not sure)at linisan ang fuel injectors mas cheap yon kesa mag bukas ka kaagad ng transmision.
    Nov 2003
    pwede rin fuel filter but i doubt this. it's the easiest thing to check tho so you may want to consider havng this done first so that di clutch agad yung gastos
    ganito din sakin di ko rin mahuli kung bakit nagkakagnun ang clutch ko. bago lang clutch ko eh.
    Jan 2004
    guys how to clean the fuel injectors ? madali ba i diy ?
    Jan 2004
    use na lang yung mga fuel injector cleaner. yung hinahalo sa fuel. marami yan sa ace hardware, true value. mahirap i-DIY yan kasi may mga sensors pa yan e. bak ma-disgrasya, lalong lumaki gastos mo.
  17. #17
    pero effective ba ung mga nabibili na fuel injector cleaner na hinahalo lang sa gasolina?
    Feb 2004
    yes effective yun ma nga yon mag hanap ka ng seafoam brand kung meron diyan.
    Jan 2004
    pag hinalo mo sa gasoline yon, san ang bagsak ng dumi ? sa Fuel Filter ba ? so definitely palit ka nadin ng fuel filter ???
    phillipogi
    try mo din palinis ng throttle body. minsan yun din culprit. yung sa akin ganun din pag nasa 1st gear tapos bitawan mo gas may jerking movement din. pinalinis ko TB sa Fusion R ayun ayos na
jerking at low gear...ano kaya problem?
