Results 1 to 10 of 10
May 25th, 2007 08:20 AM #2
kainis naman yan wreckanic na yan. let us know what shop/name para maiwasan na.
May 26th, 2007 04:03 AM #3
kung sinunod niya yun timing marks eh wala naman sigurong problema yan. kung mayrun di nakatapat may iba tunog sa redondo mo yan or a simple "tak" sound ibig sabihin something broke...sana hindi. baka wala ka lang gas...joke.
Tsikot Member Rank 5
- Nov 2003
- 3,848
May 27th, 2007 09:11 AM #4well make sure may kuryente muna. should be easy naman to check if the coil works or not.
kung meron then baka the belt is off. pero kung 1 tooth lang dapat aandar pa yan. it won't start kung off sya by a lot.
May 27th, 2007 12:54 PM #5
sought for a second opinion from a mechanic and had my timing belt re-installed... then i also had my distributor checked. as it turns out, i had a failed igniter? may naka-encouter na ba sa inyo ng ganito after changing the timign belt? anyways, now that its up and running, i think i've learned my lesson and hte next time i need something done on my car, i'll go to speedyfix.. hehehe... kahit mejo malayo..
- Nov 2003
- 3,848
May 30th, 2007 08:49 AM #6the igniter can give at any time. natsempo lang siguro na nangyari when the timing belt was being replaced.
