Results 1 to 10 of 10
May 24th, 2007 01:53 AM #1
peeps.. ano ba effect sa engine ng incorrectly installed timing belt? yung timing belt ko kse na-align sa TDC (top dead center) na pang d15 engine, while my engine is a d16 (its a PH16 honda civic ESi, correct me if im wrong though) possible kayang may masira sa makina, say the valves, cylinder head,etc? thanks in advance. pasensya na kung ang kulit ko ha.. i'd rather believe what this forum has to say than to believe the mechanic who messed up my car...
btw, im asking this kse medyo worried ako na baka may nasira na nga sa engine. ilang beses kse sinubukan na paandarin yung makina, but then it just cranks up but doesnt fire up.. in the end, yung ignition coil na and itinuro nung "wreckaniko". hehe.. i
BANNED BANNED BANNED
- 3,790
May 24th, 2007 06:01 AM #2it won't crank properly... like what you are experiencing.
pull-out you car from that shop and have it towed (say perhaps SPEEDYFIX can help) to a better shop na sanay sa civic.
May 24th, 2007 12:55 PM #4
either this or kung medyo desperate na, kontakin mo pa din si Migs (Speedyfix) and ask him if you can borrow one of his mechanics after their operating hours para puntahan ang oto mo.
Of course yung expenses ng mechanic (pamasahe, meryenda, etc.) eh sagot mo. I think this is cheaper compared to putting your ride on a flatbed and sending it to Speedyfix, but of course it all depends kung papayag si Speedyfix.
May 25th, 2007 08:20 AM #6
kainis naman yan wreckanic na yan. let us know what shop/name para maiwasan na.
May 26th, 2007 04:03 AM #7
kung sinunod niya yun timing marks eh wala naman sigurong problema yan. kung mayrun di nakatapat may iba tunog sa redondo mo yan or a simple "tak" sound ibig sabihin something broke...sana hindi. baka wala ka lang gas...joke.
Tsikot Member Rank 5
- Nov 2003
- 3,848
May 27th, 2007 09:11 AM #8well make sure may kuryente muna. should be easy naman to check if the coil works or not.
kung meron then baka the belt is off. pero kung 1 tooth lang dapat aandar pa yan. it won't start kung off sya by a lot.
May 27th, 2007 12:54 PM #9
sought for a second opinion from a mechanic and had my timing belt re-installed... then i also had my distributor checked. as it turns out, i had a failed igniter? may naka-encouter na ba sa inyo ng ganito after changing the timign belt? anyways, now that its up and running, i think i've learned my lesson and hte next time i need something done on my car, i'll go to speedyfix.. hehehe... kahit mejo malayo..
- Nov 2003
- 3,848
May 30th, 2007 08:49 AM #10the igniter can give at any time. natsempo lang siguro na nangyari when the timing belt was being replaced.
repair kit lang. car care nut says, for toyotas, he recommends entire assembly replacement for...
rack and pinion repair
