Results 1 to 10 of 10
    Jun 2010
    Guys Please help naman po. about my ride it`s Nissan Vanette 1996 model with car alarm and keyless entry.
    sa Passenger seat ko it wont lock properly pag ginamit ko yung keyless entry ko and matigas din minsan.and i recognized na hindi na sya pantay, kung baga hindi na sya saktong sakto.,
    2nd is yung sliding door ko hindi na sya nasisira ng maayos kahit gaano pa kalakas ang pag sara mo still naka usli yung door
    Im just worried kasi baka bigla nalang bumukas yung door while running
    Please Help po! taga Laspiņas po ako
    Feb 2010
    paayos mo siguro sir sa mga nagrerepair ng banga ng kotse kayang kaya siguro nila ipantay ulit yong mga pinto ng kotse mo..
    Jun 2010
    Quote Originally Posted by JaYaRxy02 View Post
    the problem is baka ma over price ako ng papagawaan ko sino na po ba mga naka experience neto?
    Feb 2009
    Quote Originally Posted by aijie28 View Post
    which is priority to you? quality or price? i would rather pay more and in fact give 10% more to the person who directly worked on it as a sign of satisfaction than having to come back to that shop who charged less and i get inconvenienced having to visit them two or more times for the same concern.
    Nov 2006
    sir ganyan din dati problema 96 vanet ko. check mo yung hinge sa front passenger door baka bagsak na at yung latch baka nabalatan na yung plastic cover. sa sliding naman, check mo yung rubber stirps baka warped na...
    Apr 2009
    sir, try mo kaya i-adjust yung door striker? usually it is held by two or three screws, meron siyang konting freedom for adjustment and alignment (you could slide it horizontally or vertically) to conform with any misalignment of the doors, you just have to loosen the screws a bit (DIY). medyo trial and error nga lang po to get the right fit. hope this helps.
    Jun 2010
    Thank you sir i think this would help try ko mamaya:2thumbsup:
    Apr 2009
    you're welcome.
    i'm not quite familiar with nissans, and i'm speaking of my experience with my civic, pero there's nothing wrong in giving it a try di ba?
    sana maayos mo sir.
    Jun 2010
    thanks sayang di ko naayos kanina even bukas too BC, board exam ng asawa ko
    Jun 2010
    Thanks to sir garfield_08 solved na yung sliding door ko i think a little more grease then ok na yung lock ko nalang sa isang pinto ang hindi pa papaayos ko nalang yun its just central lock problem
Doors Wont close properly HELP!
