Results 1 to 10 of 10
June 30th, 2010 10:51 PM #1
which is priority to you? quality or price? i would rather pay more and in fact give 10% more to the person who directly worked on it as a sign of satisfaction than having to come back to that shop who charged less and i get inconvenienced having to visit them two or more times for the same concern.
- Nov 2006
- 201
July 1st, 2010 04:54 PM #2sir ganyan din dati problema 96 vanet ko. check mo yung hinge sa front passenger door baka bagsak na at yung latch baka nabalatan na yung plastic cover. sa sliding naman, check mo yung rubber stirps baka warped na...
July 1st, 2010 05:01 PM #3
sir, try mo kaya i-adjust yung door striker? usually it is held by two or three screws, meron siyang konting freedom for adjustment and alignment (you could slide it horizontally or vertically) to conform with any misalignment of the doors, you just have to loosen the screws a bit (DIY). medyo trial and error nga lang po to get the right fit. hope this helps.
- Jun 2010
- 354
July 1st, 2010 05:25 PM #5
you're welcome.
i'm not quite familiar with nissans, and i'm speaking of my experience with my civic, pero there's nothing wrong in giving it a try di ba?
sana maayos mo sir.
- Jun 2010
- 354
July 2nd, 2010 12:11 AM #6thanks sayang di ko naayos kanina even bukas too BC, board exam ng asawa ko
- Jun 2010
- 354
July 2nd, 2010 09:55 PM #7Thanks to sir garfield_08 solved na yung sliding door ko i think a little more grease then ok na
yung lock ko nalang sa isang pinto ang hindi pa papaayos ko nalang yun its just central lock problem
Thread was made nung 2018 pa po sir.
