Results 1 to 10 of 11
February 14th, 2006 09:14 AM #1
I noticed my car slightly veers to the left whenever i stepped on the brakes. What might be the cause? Di naman nagpu-pulsate.
February 14th, 2006 09:21 AM #3
- baka di parehas ng hangin ang mga gulong or
- di properly aligned yung mga gulong mo sa harap.
February 14th, 2006 09:38 AM #4
have your front tires checked.. probably wheel alignment and balancing..
February 14th, 2006 01:47 PM #8
My analysis is that if it's because of alginment and wheel balancing, then why does it happen only during braking? I have a hunch that my right front brakes are not working.
February 28th, 2006 03:21 PM #10
na-experience ko rin yan with my ES na civic. Slight lang naman ang kabig when braking. It went away when I replaced by tie rod, ball joint, stabilizer link and front suspensions. Problem is I dont know which one was causing it. Hope this helps. =)
Naalala ko iyong 2013 SJ Forester ng relative namin. FMC change siya ng time na nakuha sa casa. ...
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
