Results 1 to 8 of 8
- Nov 2002
- 82
October 29th, 2003 07:01 AM #1di ko alam kung sa electrical ang problema may time na pag start ko ang kotse ko palyado pero minsan pag start ko ulit hindinaman nagpalit na ako ng fuel filter at mga spark plugs pero ganun pa din parang la tsamba lang minsan palyado minsan pag start hindi di ko talaga maisip kung ano ang problema may nagsabi na baka daw mga sensor needs cleaning tapos kahapon bumili ako ng fuel injector cleaner wa effect ganun pa din i really need help please reccomend a good auto shop that can fix the problem na kakairita kasi e one more thing nangyayari lang yung palya sa starting pero pag tumatakbo na ok naman siya and yung pinalit kong plugs inalis ko ulit dahil parang fake lalong pumalya ang kinabit ko na lang e yung dati ko na ngk plugsplease pm me if you this happened to you salamat sa help my car is lancer gli 95 efi
October 29th, 2003 10:11 AM #2
EFI... hmmm, my primary suspect is your EGR unit causing erratic rpm's.
October 29th, 2003 12:01 PM #3
hindi kaya sa HT wires mo yan or sa distributor or ignition coil ba yun?
- Nov 2002
- 82
October 30th, 2003 06:46 AM #6may be sa sensors nga may time na ok e so i will check and clean pajero kid san located ang mga sensors do i need to open the entire injector unit
October 30th, 2003 03:43 PM #7
May sensor siya sa intake (MAF o MAP?). Hindi ko alam pano linisin, eh. :D
parang some of the countdown timers along taft ave manila, aren't functioning today... or am i...
SC (temporarily) stops NCAP
