Results 1 to 9 of 9
March 2nd, 2006 09:08 AM #1
Hi guys I just want to ask if what coolant do you recommend to be use for liteace 92 model? I havent not tried to use coolant before.
Tsikot Member Rank 5
- Nov 2003
- 3,848
March 2nd, 2006 10:06 AM #2they're pretty much all the same. try prestone or castrol coolant nalang.
March 2nd, 2006 10:35 AM #3
Originally Posted by speedyfix
Your reply will be really appreciated.
March 2nd, 2006 01:03 PM #4
pwede din yung caltex coolant. 50/50 mixture with distilled water. red yung color ng coolant ng caltex same with the coolant ng toyota.
March 2nd, 2006 01:50 PM #5
ok..san po ba nilalagay ung coolant sa reservoir o dun mismo sa radiator? pag naglalagay kc ako ng distilled water sa liteace sa reservoir ako nag lalagay? i mimix lang po b un dun o drain ko muna radiator den lagay ng coolant den mix with water? pls advice.. tnx
March 2nd, 2006 03:00 PM #6
drain mo muna yung radiator para malinis mo narin. then pour the 50/50 mixture of coolant and distilled water sa radiator. lagyan mo rin yung reservoir.
- Jun 2005
- 3,774
March 3rd, 2006 09:39 AM #7drain ur radiator. may drain plug yan. hanapin mo na lang. sara mo na yung plug. tapos buhos mo yung mixture ng coolant/water sa loob ng radiator. with the rad cap off, turn on the engine, rev it slightly para bumaba ang tubig at mawala ang air pockets. antay ka lang na maginit ang engine at bumukas ang thermostat tapos pour the remaining coolant/water solution sa radiator kung di pa puno. kung puno na, isara mo na yung radiator. tapos dun ka naman sa reservoir. lagyan mo lang ng about 1/2 ng reservoir tank. tatapon din kasi yan eh.... sayang.
may iba pala, ang ginagawa about 2 liters ng coolant tapos 2 liters of water. (depende pa din gaano ang capacity ng radiator mo) hinahalo muna nila sa isang balde bago ibuhos.
about dun sa conversion, i doubt kung may gagawa nyan. hanap ka na lang ng 3-row talaga. kung taga sucat ka, punta ka dun sa uratex office sa may service road. dun ang distributor ng evercool radiator.
March 3rd, 2006 10:06 AM #8
try mo inquire sa Evercool kasi gumagawa sila ng customize na radiator. a friend of mine nagpagawa ng radiator sa kanila para sa landcruiser 80 series nya. ok naman ang gawa nila. nasa 7k yata yung price depende sa design mo. i think sa laguna yung main office nila.
btw, when you drain the radiator linisan mo nalang din by running continuous water (gamit ng hose) para matanggal mga dumi sa loob. then pag malinis na yung water na lumalabas sa drainage nya close the drain plug. tsaka mo na ilagay yung 50/50 mixture of cooland and distilled water. dapat distilled water yung gagamitin mo para malinis.
- Nov 2003
- 3,848
it seems this company is slowly dying.... only service for Metro Manila will now be in Alabang only...
Volkswagen Philippines launches 5 new competitive...
