Results 1 to 5 of 5
BANNED BANNED BANNED
- Jul 2003
- 2,267
November 16th, 2005 12:27 PM #1yung civic esi A/T ni misis ay nakasalang sa isang unscheduled and unwanted overhauling job.
nway, gusto ko lang magka idea kung magakano na itong mga kailangan namin. i assume mas mahal ito sa toyota na gamit ko.
overhauling kit (anu ba included dito sa kit na ito??)
piston ring (stock size lang)
timing belt
engine support
isang tanong pa, sabi kasi ng mekaniko ndi na niya daw gagalawin yung cylinder head. anu po ba suggestion niyo??? i pagalaw na din (grind etc.) or wag na???
tnx
- Sep 2005
- 188
November 17th, 2005 11:20 AM #2yung mechanic ko taga honda mura lang sumingil kaya lang ang layo mo pala. makakadiscount pa yun sa mga parts kse sa branch nila kukuha. anyway yung overhauling kit ay isang set ng lahat ng gasket, oil seal, etc. for the engine, mas maganda kung orig ang kunin mo para matibay talga. Ung replacement lang nasa php900 na for my car (bili ko 2 weeks ago). Piston ring mahal yan. Timing belt cguro under php1000.
Kung general overhaul, dapat lahat gagalawin. Expect php30,000 up expense (machine shop included)
November 18th, 2005 01:23 AM #3
30 grand for overhaul? It's almost equivalent to an engine swap. I suggest you get PH16 VTEC (from 96-00 VTi).
November 18th, 2005 01:46 AM #4
yung sa Top Overhaul done sa 626 AT ko dati inabot ng 15K (all in all)... that should give you an idea. (since my car has more expensive and scarce parts.)
- Jul 2003
- 2,267
November 18th, 2005 12:18 PM #5ndi naman talaga overhaul. mejo kelangan lang ibaba yung crankshaft due to a vey small bolt problem (kaya unwanted and unscheduled). and since ibinaba ang makina, eh papalitan na yung lahat ng pwedeng palitan para isang baba na lang. wala naman problema sa piston and piston ring pati na rin yung sleeve. iniisip lang na palitan yung ring kasi isang dekada na din yun na ginagamit.
nway, will try to go for the original ones.
tnx.
Interesting thread—really important to consider the broader impact of the National ID Law beyond...
National ID Law
